yogi154 wrote:Hi Bruce
Wondering what temps are you getting ???? I towed out thirty five miles last weekend at 80 plus temp . axle temp was about the same temp around 85 deg . and tires were 100 degs I thought the temps were good but don't have any thing to compare to The truck tires were 115 deg I guess that's ok too
Happy Camping Wayne
My hubs seem to run about 20 to 25 deg over outside temp so I think you are good there and I have seen similar tire temps, don't worry about pressure, it should only be checked and adjusted when the tires are cold.
Bruce
