Pin Weight
- bayoubengal
Pin Weight
Does anyone know if the pin weight becomes a little lighter if the FW Tank is located to the rear of the axles and filled?
Vince & Kim
2008 31RKLE
Nights Camped:
'02--74 '06--122 '10--24
'03--59 '07--47 '11--44
'04--83 '08--98 '12--76
'05--99 '09--84
2008 31RKLE
Nights Camped:
'05--99 '09--84
- gmarker
Yep. It will increase the total weight and decrease the pin weight. Theoretically, you could put enough weight behind the axles to lift the rear of your truck. Although the weight of the filled water tank won't make enough difference to tell without a scale.
