Page 2 of 2
Posted: Mon Aug 27, 2007 3:11 pm
We are full-timing in the 30TS with a 3500. The reason we went with a 1-ton is because we were going full-time.
Posted: Tue Aug 28, 2007 3:44 am
by mtiller
Thanks jennyt,
My 07 F-250 w/ PSD actually has a GVW of 10,000 lbs. I am taking it to the scales tonight, but I have seen other postings where the truck should come in at about 7500. After adding a few things, I expect to have about 2200 available for pin. The advertised pin is 1970, but wanted to see how accurate that would be. We don't load very heavy either, so with an approx pin of 2100, that sounds good.
How does your F-250 handle with the trailer in tow?
Posted: Tue Aug 28, 2007 3:47 am
by mtiller
By the way, how do you like the Timbrens? I was thinking of getting a set myself.
Posted: Wed Aug 29, 2007 4:23 am
by jennyt
Posted: Wed Aug 29, 2007 5:31 am
by mtiller
Well I finally got the truck to the scales last night. It weighed in at 7460# with me, wife, full tank of fuel, and a couple of extra bags that just happened to be with us at the time. Add in approx 150 for a hitch and 40 for the 2 little dogs and it should come out to roughly 7650#.
The specs on my F250 are 10000 GVW, 6100 rear axle, and 23000 GCVW.
Just for argument, I'll use the 20% rule with the 5er, which is approx 12,500 empty. I know that will go up when we add our stuff, and an option or 2, but I think using 20% of the spec should give me a reality figure I can work with.
So, I should end up with a pin of 2500 and a loaded trailer (we pack light also) of approx 13,500. That means the numbers should look something like:
GVW 10,150 - over by 150
Rear axle 5550 - under by 550
GCVW 21250 - under by 1750
All things considered, I don't think 150# over GVW is going to concern me, and it will probably be a little less than that since I added over 500# to the pin weight just to get closer to reality. I'm happy with this and will likely put in my order for the new bird by the end of the week.
Thanks for all the info.
Posted: Wed Aug 29, 2007 6:08 am
Fill your fresh water tank (rear mounted) and it will reduce your pin weight more than enough to keep your truck under it's limit, just travel with waste tanks empty and fresh full.
Posted: Wed Aug 29, 2007 6:55 am
by mtiller
Good tip. Thanks, I'll keep that in mind if the numbers get to close.
