New 33TBH and Chinese Tires
pops91710
Cardinal Owners: 2006 30 WB LE
Post by pops91710 »
campswithcritters wrote:I still will back my Michelin XPS Ribs, they are all under the weight rating at 80 psi, no problems in over 24000 miles and tread wear is minimal. I will buy these tires again because of the durability and general good performance. I will also likely put them on my truck when replacement is due.
No one can blame you for your preference or position. I tend to lean towards the Michelins or Firestones. My trailer, as heavy as it is for me, is not the heaviest of the lot. So, the Michelins will indeed qualify weight wise.
Your choice to use The M's obviously has proven to be a good one for you. All I am saying is I think that is why Forest River does what it does.
Mike Harrington, Chino, CA.
2006 Cardinal WB/LE 30'
No offense taken Mike, if I find a product that works I like to recommend it. Michelin has done that for me in this case,
Cardinal Man wrote:I replaced my Kendas with BF Goodrich Commerical tires and so far it's been over a year and no problems. If I were you I would take those chinese tires off your camper they are a accident waiting to happen.Sorry that's just the way I feel about them have heard of to many people getting thousands of dollars damage to there campers from these chinese tires.
Charles
I've been looking at these tires (BF Goodrich Commerical) as a replacement on my trailer. Have you noticed a difference in gas miliage with these. Of course around $100 a tire difference between these and the Michelin XPS means a 1 or 2 mpg loss with the All Weather tread it would take a while to make up the difference. Also I do pull the trailer on USFS roads, so how do the sidewalls take scuffing from rocks, and have you noticed if they are prone to picking up gravel in the tread. I tow often on these roads and this is one big reason why I have a 4x4. Nothing like it when you have to stop while going up a steep grade on a gravel road towing a trailer, and then getting restarted without spitting gravel into the coach like you do with a 4x2, if you can get started at all. Go to 4Low and walk right up the hill. Which I prefer to the alternative, backing down the hill around curves.
And BF Goodrich Tire was bought by Michelin in the early 1980's just for info.
gdc4christ
Post by gdc4christ »
Bought used 2003 33ts in April this year thought tires looked like new. We had pulled about 1,000 miles and last week had 2 tires blow out. Had tire dealer look at the tires, they were original made in 2001, but had no weather checks and looked like new. Had always been told RV tires should be replaced every 3-4 years made a believer out of me.
These were Kenda tires.
C.B.
Post by C.B. »
Replaced the Kenda's on the 5er with Michelen XPS RIB'S
Replaced the original equip tires on the Ford with Michelen LTX MS
Gives me almost as much peace of mind as my 16K SuperGlide hitch.
C.B. wrote:Replaced the Kenda's on the 5er with Michelen XPS RIB'S
The LTX MS are going on my truck down the road also. Have Toyo and they do ok but wont get the 50k out of them. I still have the OEM Michelin's in my shop with half tread so I will put them back on this coming spring.
