airlock when filling water tank?
Posted: Fri Jul 13, 2007 3:02 am
by markj
on my 31RK, I sometimes get an airlock (I think) when trying to fill the fresh water tank. The dealer said to unscrew the drain pipes, and it seemed to work, but I couldn't get it to accept water yesterday. Backed up out the spout! Does anyone else have this problem? Best fix? Thanks. Mark
Posted: Fri Jul 13, 2007 5:45 am
by snuffy
Sounds like a vent tube could possibly be kinked.
Posted: Fri Jul 13, 2007 6:31 am
snuffy wrote:Sounds like a vent tube could possibly be kinked.
Hi Mark, like Wally said, it sure sounds like the air you're displacing is not finding a way out. I'm afraid I don't know where the vent is located. I would suspect on the roof toward the back of the trailer but I don't know for certain. I'm sure there are others here that do know and will chiming in shortly. BTW, how full does the tank get when this starts happening?
Posted: Fri Jul 13, 2007 6:43 am
by markj
It does it from the get go. The tank light showed one light on--maybe 1/4 full this time.
Posted: Fri Jul 13, 2007 4:12 pm
I know this may seem like a silly question but is there any chance that the tank is full and the indicator is wrong? Just a thought, I wouldn't put any money on it.
Posted: Fri Jul 13, 2007 5:07 pm
by snuffy
You could have a kinked intake hose also or an obstruction.
Posted: Sat Jul 14, 2007 5:27 am
by Brent & Susan
Hello I have the same rig and have had the same thing happen to me twice at home and once at the campground. The dealer told me that some times the vent tube nest to the fill hole gets water in it and to blow it out with pressureized air. The one time I was able to blow it out by hand. Good luck and keep us posted. Brent
Posted: Sat Jul 14, 2007 5:34 am
by Shields
It happens to ours regularly. I just let it bubble out, put the hose back in and if then fills without problem.
