Cable/Antenna
Cable/Antenna
Need a little help in this natter-----what do you do to switch from antenna to cable on the TV at a camp ground? Is there any switch to turn over from one to the other. Thanks! Got a Cardinal flag now need the pole ---- nice looking --- can't wait to fly it over the bird.
Re: Cable/Antenna
I personally go out and disconnect the cable, raise the antenna, and turn on the booster. The reason I disconnect from the cable is that an antenna booster will back feed through the cable and ruin all the neighbors picture on cable. Many campgrounds warn of this in the check-in guidelines.Rosie F wrote:Need a little help in this natter-----what do you do to switch from antenna to cable on the TV at a camp ground? Is there any switch to turn over from one to the other. Thanks!
Bruce
- Cardinal Owners: 2002 Cardinal LX
