Anyone add shelves or add'l cabinet in bathroom?
We have the enclosed bath in our 2008 LE 30RK. We would like to add either another med cabinet or shelves behind the toilet. This would be the back of the entertainment center wall, where the control panel and many of the lights and fans are wired. Does anyone have any suggestions as to how to mount anything on this wall? We absolutely love our bird, but did give up some convenient storage options we had in the 2003 RL Sierra.
We've also wondered how we might install a grab bar for the steps up to the bed/bath area.
Thanks,
Karen
Thanks,
Karen
Ours isn't behind the ent center so will leave that question for our resident experts!
But....we do have a factory grab bar going upstairs to the bedroom...I thought all the units came with them...you might want to contact your dealer on that one.
Congrats on your new rig!! Those enclosed baths are nice!!
Karen,
I just toured the factory yesterday as stated in earlier post and looked at that exact wall closely so I would know about the same cabinet issue. The wall that the cabinet would mount on above the toilet is built of 2 x 2 wood stock with the paneling over the top of it. The studs are what appeared to be about 12" on center and I did not see any wiring in that area that you would have to worry about. I will probably mount a cabinet in the near future myself and plan to use screws of the proper length. Tap around and find a stud and make sure a couple of screws go into the stud, The wall stud on mine is right in the middle of the wall and easily found.
Take care,
Kevin
Take care,
Kevin
Grip rail for stairs
About the grip rail. We were concerned as well. My wife tripped going down the stairs at night in the dark and got a couple good bruises. I took the grip rail on the inside of the entrance door and put it by the thermostat and bought a good looking short oak towel rack at Lowes and mounted it in the same place entrance grip rail was located. It cvost me about $14. You would think it was factory installation.
Our inside steps are on the far right, if you're facing the front (bedroom) of the trailer, and the risers are probably as high as those on the stairs outside, difficult for someone with bad knees! (I've asked for the four step replacement for my birthday!) The right wall would be the outside wall; I'm not sure where we could find strength enough to install a grab bar there, aren't these aluminum studs? The left wall is the bathroom wall, with a pocket door, not the strongest wall either. I think next week I'll give the dealer a call and see if a grab bar could be installed on that outside wall somehow. After all, there are heavy cabinets hung on those outside walls!
I'd also wondered about an oak towel bar! Good to know it would work, thanks!
Karen
Karen
