Manual adjustment for landing gear?
Hi friends, due to my recent problem with the slide that would not retract (now fixed thanks to everyone's help) I was trying to locate a way to raise and lower the landing gear in the event of a problem with that system. I have an extra hand crank that came with the Cardinal that I haven't found a use for and assume that somewhere there is a socket it fits to adjust the landing gear legs. Can anyone confirm and tell me where the socket is located? If not, what are other means of adjusting the landing gear if the motor fails? Thanks in advance to all.
Bruce is correct the location is in the propane compartment. I don't know if they are all the same but on my 29WBLX model it is on the street side (driver side) inside the propane compartment just in front and above the propane tank.
The post by Al about hooking up to your tow vehicle connection like you were going to tow has worked for me before as I stated in the reply in the slide won't retract section. I would definitely try that before I attempted to crank it up by hand. I have had to cranked up empty semi trailers before and it is not an easy chore.
