On our 2000 bird I used the standard MaxaxAire with the fanastic fan as it was a manual operated cover. It didn't pose a problem that it could only be opened part way as we usually just used it as an exaust fan when cooking to keep that darn smoke alarm from going off. On the new bird the fanastic fan is controlled by the wall mounted control and when used on automatic, which is how I want to use it, the motor on the vent cover raises it all the way up. I want to install a cover so the fan can be used when it is raining and also it provides some protection from hail.
Have any of you installed a vent cover over your automatic fantastic fan and what kind are you using to give you proper clearance? Thanks
Which Vent Cover with Fantastic Fan
2008 Cardinal 34QS
Kodiak Disc Brakes
Kodiak Disc Brakes
Looks like I found my answer on RV.Net Open Roads Forum. Found long discussion on this topic and looks like most folks are using the MaxxAir Fan/Mate Model 800 with the fantastic fan.
2008 Cardinal 34QS
Kodiak Disc Brakes
Kodiak Disc Brakes
Fan Cover
Don,
I contacted Fan-tastic Vent and talked to their head Technician Bob Beratta 1-800-521-0298.
His recommendation was not to put a cover on the fan because you lose 40% efficency of the fan when you install a cover and lose another 20% efficency if you install one with a filter.
The issue with the cover is when you lose efficency you do not move as much air in or out of your trailer so it takes longer to pull hot air out or cool air in. When you are not moving as much air the dirt and dust stays inside the cover and gets on the electrical componets and you really have no way to clean it with the covers on.
He did state - However if you are going to go ahead and install one get the largest one you could get without a filter. Which would be the Maxx Air 800
He welcomed anyone with a question to contact him or one of the other Technical Support team @ 1-800-521-0298
Bob Beratta
Steve Milks Jr
Rodney Florida
Jeff Atwell
Here is the link to their website
http://www.fantasticvent.com/contact_us/contact_us.html
Bob Beratta
Steve Milks Jr
Rodney Florida
Jeff Atwell
