Cardinal 30TS
Cardinal 30TS
Postby Artsville » Sat Oct 06, 2007 3:43 pm
Hi Everyone....
Doing some homework on our first 5ver purchase. Saw the 30TS at the Sacramento RV show. We really liked the plan, but have a question with the slides in. Is it possible to access the fridge with the slides in? If so how much space is there between the two slides when closed?
thnx a lot....
art
Artsville
Postby Traveler II » Sat Oct 06, 2007 5:10 pm
We pick up our new 30 TS on Monday. We liked the floor plan but when the slides were in you would not be able to get to the back of the rig. We have been told that what we can do is to take the table and turn it sideways, and that will give us the room we need to get to the back. Based on that we ordered from a dealer a unit with the options we wanted.
Postby Future Fulltimers » Sun Oct 07, 2007 8:56 am
Welcome to the club, Artsville
What we did was to unbolt the table and switch the couch and the table. This works for us because we don't use the couch.
If you unbolt the table and turn it sideways (if you don't move it like we did), put a chair on each end then the remaining two chairs in the in the center of the table. You will have plenty of room to get by. If you do this make sure all the table legs are on the ground and the chairs are pulled up to the table. This will keep the table & chairs from moving around and possiably tipping over. :shock:
Who is online
cron
