Arctic package
Posted: Sat Oct 27, 2007 1:17 pm
by buckaroo
Could someone explain "arctic pac" is that an option ,or is it standard on all Cardinals ?. Our new 30WBLE arrived on Friday ,and now it is just hurry up and wait for the dealership to do there thing
Great forum lots of information .
CAN"T WAIT TO TAKE IT ON A TRIAL RUN AND CHECK OUT ALL THE NEW TOYS.
Posted: Sat Oct 27, 2007 2:00 pm
The "arctic pac" was a option a couple year ago, the package consist of heating the tanks, installing a underbelly with insulation.
I think it is standard on all Cardinal units now because I have build sheets for all the models made and do not see it as a option on any model.
Posted: Sun Oct 28, 2007 3:40 pm
buckaroo, check my post on the "On the road" forum. All the tanks are heated, however if you let the water run to keep from freezing the hose you'll need to switch off the tank heaters (it's recommended you keep the level at 1/3 or above when you use the heaters), get heat tape for the hose or fill the fresh water tank and turn on the heaters when its really cold. I plan on getting some heat tape for the hose for when I'm in a park in freezing weather.
Congratulations, and I hope you have as much fun as I am!
Posted: Mon Oct 29, 2007 6:45 am
by markj
just out of curiosity, is the fresh water tank also heated when the tank heater switch is switched on?
