Arctic package
buckaroo
Cardinal Owners: 08 30 WBLE
Contact:
Arctic package
Post by buckaroo »
Could someone explain "arctic pac" is that an option ,or is it standard on all Cardinals ?. Our new 30WBLE arrived on Friday ,and now it is just hurry up and wait for the dealership to do there thing
Great forum lots of information .
CAN"T WAIT TO TAKE IT ON A TRIAL RUN AND CHECK OUT ALL THE NEW TOYS.
Buck & Heather and our two furry friends Kirby and Rara
08 30 WBLE /32" Flat screen tv , O6/GMC/D/A 2500HD BANKS EQUIPED.
" ON THE ROAD AGAIN "
The "arctic pac" was a option a couple year ago, the package consist of heating the tanks, installing a underbelly with insulation.
I think it is standard on all Cardinal units now because I have build sheets for all the models made and do not see it as a option on any model.
buckaroo, check my post on the "On the road" forum. All the tanks are heated, however if you let the water run to keep from freezing the hose you'll need to switch off the tank heaters (it's recommended you keep the level at 1/3 or above when you use the heaters), get heat tape for the hose or fill the fresh water tank and turn on the heaters when its really cold. I plan on getting some heat tape for the hose for when I'm in a park in freezing weather.
Congratulations, and I hope you have as much fun as I am!
markj
Post by markj »
just out of curiosity, is the fresh water tank also heated when the tank heater switch is switched on?
2007 Cardinal 31RKLE
Hijacker 21K underfloor mount
Fifth Airborne pin box
1990 Seaswirl fishing boat!
Kiki (the cat)
