Anode Rod
Anode Rod
Postby hillbilly » Thu Feb 07, 2008 9:29 am
I have seen somewhere that you could get a anode rod with a flip valve on it so you could drain the hot water heater with out removing the rod itself. Has anyone seen this, if so where can you get them. Mine is eat up after one year. I'm sure this is from not draining the heater after each trip. Spring is on us folks! LET'S ROLL!!!! :lol:
hillbilly
Postby Luizianna » Thu Feb 07, 2008 9:37 am
We just put one on our rig....but it's a twist valve. Got it from Camping World
Luizianna
Re: Anode Rod
Postby Rob & Cathy » Fri Feb 08, 2008 4:31 pm
hillbillystuarthillbilly wrote: I'm sure this is from not draining the heater after each trip. Spring is on us folks! LET'S ROLL!!!! :lol:
I doubt that's the reason. I never drain my water heater and when I replaced mine after the first year I had lots of the rod left. Just a thought.
Anode rod
Postby spskatt » Sat Feb 16, 2008 5:57 pm
I stopped at Camping World and they had never heard of a anode rod with a drain. Does a water heater need a anode rod? Could we just put a twist valve in place of it?
spskatt
Re: Anode rod
Postby rosey » Sat Feb 16, 2008 6:20 pm
spskatt wrote:I stopped at Camping World and they had never heard of a anode rod with a drain. Does a water heater need a anode rod? Could we just put a twist valve in place of it?
The annode rod helps prevent your water heater from rusting thru from the inside out.
rosey
Postby dennis1949 » Sun Feb 17, 2008 6:21 am
I bought one yesterday at my local rv dealer. Cost me $15.00. I believe it will be worth it Because I drain my hot water heater when I get home from a trip.
Dennis Carpenter
2016. Blue Ridge 3045RL
2012 3/4 GMC Z71 truck
Decatur Al.
dennis1949
Who is online
Users browsing this forum: No registered users and 2 guests
cron
