When to use?
ratherbcamping
When to use?
Post by ratherbcamping »
When should I turn on the switch for the heated tanks? How cold should it be before I need to worry?
WP903
Post by WP903 »
They are themostatically controlled. Turn on the switches if you think it is going below 45 degrees. I believe they kick in at 42 degrees.
roger5438
Cardinal Owners: 05 30WBLE
When to use
Post by roger5438 »
See post under "cardinal Schematics" pg 8 & 9 are about the tank heaters including operating instructios. Also a precaution THERE MUST BE LIQIUD IN THE TANKS !! The prints are for a 30TS , but i'm sure tank heaters are the same on all models. roger
Roger & Sandy
Anchorage, AK
'05 30WBLE w/TrailAir Pinbox & Centerpoint suspension
'06 Ford PSD 4x4
ONAN 4300 Watt gen in tv
ratherbcamping
Another question on the tanks
Which tanks are heated? Grey water? Black water? Fresh water? Is there any way we can tell without opening up underbelly of the trailer? It is getting cool at night here, but we don't want to winterize until after our trip next weekend!
WP903
Post by WP903 »
If you have two switches, all four tanks should be heated. Your dealer should be able to tell you.
Uh, why winterize? Camp all winter! Never a problem getting into a campground, unless it is not open or is covered in a foot of snow - but we are Cardinal Owners and we are resourceful. :lol:
ratherbcamping
So if there is only one switch, which tanks are heated? I'm afraid temps are going to drop below freezing tonight -- it's already down to 37 degrees. And of course it's too late to try to call the dealer now!
Shields
Cardinal Owners: 31 RK LE
Post by Shields »
They are all heated and thermostatically controlled. Just have some fluid in the tanks and turn them on. but if you have heat going, don't sweat 37. we have been down to 10 degrees with no ill effects, other than the propane running like water.
I wish I new which ones were really heated. F.R. tells me that only my fresh water tank is heated, dealer says all are. The only thing I know for sure is you do have to have fluid in them to heat them.
