Central Vac
Central Vac
Those of you that have one is it worth $280, that is what it will cost me to add it.
It sounds good but how does it work does it work good?
Im trying to decide if I should add it or not.
thanks
thanks
Re: Central Vac
We LOVE our central vac !! The super long hose easily reaches the whole interior of the 5th wheel. The hose stores neatly in a box that fits in our closet and takes up much less room than a regular vacuum. The coolest part is that under the step leading to the front bedroom is an opening where you sweep the kitchen floor and push your pile up to it and the central vac will suck it upDiesel Dave 04 wrote:Those of you that have one is it worth $280, that is what it will cost me to add it.
thanks
- Skype ID: bill.bopra
Does the nozzle have a rotating brush or is it suction only?
Please guys this is'nt a light in the fridge question!!
Go for it, they work very well and what is great about a central vacuum is the exhast is not discharged back into the same room you are cleaning.
I store my hose in the step and the unit does come with a beeter brush for the carpet.
George:
George:
do they all come with the power dust pan also??Olbird wrote:Go for it, they work very well and what is great about a central vacuum is the exhast is not discharged back into the same room you are cleaning.
George:
Any unit built around or after January 06 will have the dust pan pick-up in the step going up to the bedroom and the pick-up outlet for the hose on that same wall going up to the bedroom.
The unit is mounted on the compartment floor near the water pump, you can also connect a hose into the unit outside also if needed to cleanup your compartment. The unit comes with a extra bag and Camping World has the bags also 2 or 3 for a couple bucks.
George:
George:
