Diesel Newbee
dpalmer
Council, Moderator
Cardinal Owners: 2018 3456
Diesel Newbee
Post by dpalmer »
We are getting ready to head for the Klamath rally and it will be our first trip towing with a diesel.
Questions :?:
How often will I need to add DEF while towing :?:
Do you carry additional container of DEF :?:
What kind of mileage should I expect with the 6.7, 3.73 dually :?:
Excited to get on the road :d
Dave & Karen
2018 3456
2021 F350 XLT, 4x4 Dually
Full-time as of 10/1/2016
Re: Diesel Newbee
DEF is available just about anywhere, I have never calculated how much is used while towing. I know that you are good for over 1200 miles with a full tank. I tow 600 miles one way to NY every year and have never added DEF until after I am home. Then I do not completely fill the tank because freezing temps are getting close.
tecosinc
Cardinal Owners: 2016-Cardinal 3850RL
Re: Diesel Newbee
Post by tecosinc »
I have a 2014 ford drw w/ same Motor and gear ratio as yours. I pull a 3030rs. I make 10 mpg on the average. I put def fluid every thousand miles. I'm sure you can go longer on def, but that's what I do. I don't carry the def fluid. Usually get it at Auto zone. Good luck.
Errol & Tina Jenkins
2016-3850RL Full Body Paint
2020 Ford F350 King Ranch FX4 DRW w/ air lift bags
Nights Out-2015-59
Club Rallies Attended-2
FROG Rallies Attended-2
jtaylor1920
Re: Diesel Newbee
Post by jtaylor1920 »
Although my truck doesn't use DEF I have seen it available in the fuel lanes at Pilot and other truck stops. Friends with trucks using DEF also have said its available at Walmart for a reasonable price.
dpalmer
Council, Moderator
Re: Diesel Newbee
Post by dpalmer »
Thanks for the info, that is all helpful :D
Dave & Karen
2018 3456
dennis1949
Cardinal Owners: 2016. Blue Ridge 3045RL
Re: Diesel Newbee
Post by dennis1949 »
Save your empty DEF jugs. When you fill the truck up fill the jugs up also. This will save you 3 to 4 dollars a gallon on the DEF This way you always have some DEF if you don't stop at a truck stop
Dennis Carpenter
2012 3/4 GMC Z71 truck
Decatur Al.
Re: Diesel Newbee
I always take off with 3 gallons that I have filled at the dealer. It will take the 3 gallons after about 2,300 miles of towing. Once I use them I usually go to O'Reillys and pick up a few gallons of Peak Blue.
Dale Crenshaw
Re: Diesel Newbee
Post by Dale Crenshaw »
Dave, the computer on my Chevy will allert me when DEF is getting low. It will say something like 250 miles or so before it runs out. This gives me plenty of warning to give it another drink. I usually just add one 2 1/2 gallon jug from WalMart, and go until it tells me to get another.
Dale
mbrolin
Cardinal Owners: 2019 Cardinal 3456 RLX
Re: Diesel Newbee
Post by mbrolin »
My 2014 Ram has a def gauge. When it gets down to just above a half on the gauge it will take 2.5 gals. Bought the truck last August and with 6k miles empty and towing I have only added 5 gals. I plan on carrying a 2.5 gal of def along on our trip next week but as was posted def is readily available. I would hope that the price at most retail outlets will come down Def is deionized water and ammonia. I honestly believe that def makers are taking adavantage of the market. Way overpriced compared to bulk. Average cost in Oregon is $13 per 2.5 gallon versus $3 per gallon at a truck stop using the truck pump ( w/ PUC) :-o
Mike & Sandy
2019 Cardinal 3456 Luxury Edition
2018 Ram 3500 4x4 Crew Cab Aisin 6spd Dually
dpalmer
Council, Moderator
Re: Diesel Newbee
Post by dpalmer »
I think I will pick up a 2 1/2 gallon at Walmart and have it with me for piece of mind. If it is due and I am fueling I will get it at the pump. The info of your experiences has really helped this new diesel owner, thanks :d
Dave & Karen
2018 3456
jacknife
Re: Diesel Newbee
Post by jacknife »
When you buy it at the truck fuel islands you may need a magnet to put on the nozzle . The big trucks have them built into the tank. It is to keep from putting it ito the Dieseltank. You can get them oline if you need one. Msybe tHE FORD TANKS HAvE OnE BUILT IN.
dpalmer
Council, Moderator
Re: Diesel Newbee
Post by dpalmer »
I had to add DEF once but used the jug I bought, The Pilot we stopped at was intimidating with trucks lined up behind me and wasn't sure how to get the DEF The sign said push here for DEF so I just left. I'll have to see about the magnet. thanks for the tip.
Dave & Karen
2018 3456
Re: Diesel Newbee
I am sure some of the people who own the newer diesels will be along to explain what they do! I have no idea since my older model Dodge does not use DEF.
2025 Nights Camped 30
2024 Nights Camped 75
Rallies Attended - 51
dpalmer
Council, Moderator
Re: Diesel Newbee
Post by dpalmer »
I am sure I will get all the info I need when we reach Klamath :thumbrt:
Dave & Karen
2018 3456
