New truck tires
trumpman
Cardinal Owners: 2013 3850 Fifth Wheel. Purchased May 2013.
2007 F350 DRW
Re: New truck tires
Post by trumpman »
The '07 calls for 75 front and 60 rear for normal driving. My tires are rated up to 80 so for towing that's where I plan to put them at.
hydehunter
Cardinal Owners: 2010 3640,2011 Dodge 4x4 dually
Location: South Dakota Stickney to Arizona in the winter
Re: New truck tires
Post by hydehunter »
on my Ram 3500 I run 60 psi in front and 45 psi rear when not towing or loaded.get a copy of the tires air pressure and load limits then weigh the front and rear to get the best air setting for your truck.this way you can get them to wear best good luck and don't let them set 80 psi in the rear or you will wear the center out of the tires
Jim and Karen Higgs
2010 Cardinal 3640
2011 Dodge 3500 4x4 dually
full timing starts 6-1-2012
