Hi,
Maybe I’m just noticing it now but my 2012 GMC 3500HD Diesel sometimes makes a thumping noise when it gears down when going up hill, I guess it’s from 6th gear down to 5th. It doesn’t do it all the time and it seems to be a bit smother if I’m using cruise control. It does it with or without the trailer in tow. I use tow-haul mode when I’m towing. It pulls well and shifts well otherwise. The trans temp is always acceptable and the trans fluid level is OK. There is 112000 KM (70000Mi) on the truck and the trans fluid and internal filter was changed at 70000 KM (44750 mi). I always have the external spin-on trans filter changed at every oil change. Is there anything here I should be concerned about? I don’t want to ask the dealership about it and be swindled into a major repair.
Thanks!
Joe
Transmission Shifting with a slight Thump
- LuvRving
- Cardinal Owners: Cardinal 3030RS
Joe and Yvonne
2012 Cardinal 3030RS
- Cardinal Owners: 2005 30TS
Re: Transmission Shifting with a slight Thump
I'd take a look at the u-joints.
Roger & Joy
2005 30TS
Morryde pin box
Morryde SRE4000 suspension
2007 Chevy 2500HD Duramax
2005 30TS
Morryde pin box
- EAW
- Skype ID: eaward49
Also consider checking the condition of the rubber around the driveshaft's center carrier bearing. You could also notice a vibration when pulling away from a stop while towing.
