CPS INFO
CPS INFO
Hello,
Hope someone can help.
TV-2000-F250-7.3. 85,000 miles.
I have been having some problems.
We have been on the road for 7 months. Diesel has been running fine until lately. I have only been able to find ULSD to run in truck. It seems to run better with low sulpher . What I have been experiencing is engine will hic cup or belch and jerk and check engine light will come on. when I stop and restart check engine light goes out and truck runs better. Seems to happen when we head out in morning.. Sometimes engine will shut down and we have to pull over and restart and then runs ok...
I have done following:
New air filter, Fuel filter replaced 4000 miles. Oil level clean and full. Use Howes additive per instructions when gas up... Drained water from seperator.
I have been reading other forums about the 7.3 having issues with CPS, which I believe is the Cam Position Sensor and what I have read this may be my problem or could it just be the fuel. I understand that replacing the CPS runs under $30.00 Should I do this?
How hard is it to replace and where is it located. I am not a experienced mechanic but I can do regular maintaince, like oil change filter change , fuel filter replace, etc.
Sure would appreciate some advice. Could we be stranded if CPS goes out completely..
Still got 3 weeks till we get back to Florida. Currently in Cloumbus Indiana and head for Cave City KY tomorrow.
Thanks for your help
God Bless
Bill and Judy
God Bless
Bill and Judy
I'll bet a new CPS will work wonders. If I'm not mistaken to located near the camshaft pulley and you need a 10mm wrench to remove it. Do a search on the http://www.ford-trucks.com/forums/ forum and I'm sure you'll find tons of information.
I'm sure that soon there will be plenty of info here from the 7.3 diesel guys on this forum.
This is from Scott (as I am blissfully unaware of all things mechanical)
Unfortunately I am having the same problems - EXACTLY as you state. I thought I had water in the fuel but it doesn’t sound like it. It started last week . I filled up Saturday and it went all day Saturday and Sunday without a burp, but this morning it sputtered. It does clear up. Water might be the case but once it happens it takes forever to run it all out. I would be curious to find out if it is the CPS.
Thought the CPS was around $100.00 (maybe dealer price)…make sure you have a 10mm wrench.
It's located underneath the front of the engine close to the Harmonic balancer.
It’s very easy to replace, and yes, you could be stranded if it goes out completely.
http://www.ford-trucks.com/forums/47605 ... lures.html
Found this - not sure what it all means but I thought I'd post it anyway.
That sounds like what happened to my 2000 Dodge Cummins when the MAP sensor (Manifold Absolute Pressure)went out. When it went out it would hicup but would continue to run.
They charged me $98.00 for the part but two hours@$98 per hour to diagnose and fix. They had to put it on their computer because the check engine light came on which was one of those hours.
Hope you solve your problem more cheaply yourself.
2024 Nights Camped 46
- Cardinal Owners: fifth wheel
$15.29 for a new CPS. Price has dropped quite a bit the past couple of years.
http://catalog.powerstrokeshop.com/part ... atalogid=1[/url]
Thank s for all the help
Well problem turned out to be to CPS or CMP whatever you call it.
Picked one up for 24.95 but had a problem... IT RAINED HERE IN KENTUCKY FOR 4 days so I was unable to get uder hood to change. Called a local Ford dealer and the put it in and while I had it in shop decided to run a diagnostic check. It was the problem . Now some on some forums say that the CPS will not throw a code. Well, mine through 2.
Again thanks for all the help.
God Bless
God Bless
Thanks for letting us know that you got it fixed. When I had my 7.3 I was on a trip and once in awhile when I came to a stop the engine would quit. It would start right up and run fine. Then once in awhile when stopping the engine would turn off. After we finished the trip I fond out it was a bad CPS and had it changed. Never had a problem after that.
