SHIFT SELECTOR PROBLEM
WELL I GOT A GOOD ONE AND HOPE SOMEONE CAN OFFER HELP.
All the sudden the gear selector shift on column, automatic ford f-250 2000 7.3 will not go into park on left side or low 1 on right side will not lock in gear. Tranny has been shifting smooth and still does just this one issue. Was told by a friend it could be a fuse but have checked all and all ok.
Anyone experience this before.
Thanks..
Thanks..
Shift lever
We just took our Jeep to the dealer last week. Our's was doing just about the same they said they had to order a new shift lever. They said that there is a computer in the lever that was bad. Has to come from Detiort. I don't know if your Ford is the same.
Chuck
Chuck
Try this link and see if it helps at all.
http://www.fordforum.com/archive/thread ... 909-1.html
If not, I have an ex-Ford truck transmission design engineer at work - he'll probably know
under the dash if you look up there is 2 small screws that come lose and cause this problem. they are tourx head screws and it is on top of the colum if you feel around you will find it.
Mine shifter works fine, but the position indicator is stuck on the 1, and does not move. It is not a problem for me, but when someone else drives the truck they are confused. Does anyone know if this is difficult to fix?
Randy, most of them have a small cable that runs under the column and it moves the indacator when the lever moves it has a spring on it so if it comes unhooked it will go all the way to low. I would pull th cover off the column and you will see what im talking about.
A BIG THANK YOU AGAIN
WELL AS HAS BEEN THE CASE Y'ALL HAVE HELPED US SAVE HUNDREDS OF $$$$$$. THANKS TO EVERYONE WHO POSTED> THE PICS REALLY HELPED. I AM NOT A MECHANIC BUT YOU GUYS MADE IT SO EASY TO JUST FOLLOW YOUR INSTRUCTIONS. WHEN I PUT THE T30 on I COULD SE HOW LOOSE. AS I TIGHTENED MY SWEETIE COULD SEE INDICATER MOVE OVER TO PARK AND WE WENT THROUGH GEARS AND ALL SHIFTED SMOOTH AND EASY>
THANKS VERY MUCH.
GOD BLESS
THANKS VERY MUCH.
GOD BLESS
Re: SHIFT SELECTOR PROBLEM
Dave, you are THE MAN, I just got around to looking at my shift indicater. It was exactly as you said. All I had to do was put the little red wire around the hook. No parts, less than 10 min to repair. Thanks to your help.
Great that it is all fixed up and your welcome. let me know if you have any other ford problems, i been working with them for years.
Dave
Dave
Randy,
I am glad you could fix it without buying a new cable that comes with the indicator. I have a tight fit to get my Bird into the building and from shifting forward and backward so much my cable broke and I had to buy a new cable and indicator ($16.00)
Not too bad of a price.
