AIR BAGS AND TORSION KEYS
rvthereyet
Post by rvthereyet »
Im thinking about adding air bags in the rear and different torsion keys in the front. Will I have a problem hooking up or unhooking. I am using a superglide hitch. The keys should give me about a 2 inch lift in the front. Currently I'm running 265/65R17 bf goodrich.
Re: AIR BAGS AND TORSION KEYS
rvthereyet wrote:Im thinking about adding air bags in the rear and different torsion keys in the front. Will I have a problem hooking up or unhooking. I am using a superglide hitch. The keys should give me about a 2 inch lift in the front. Currently I'm running 265/65R17 bf goodrich.
Sounds like you need two trucks. A toy truck (to play with) and one to do real work, like towing a 5th wheel. Chris
bilmorvn
Post by bilmorvn »
Don't know about torsion keys, but the airbags will give you no problem as you can hook up with the air dumped and pump the airbags us after you hook up. Would sugget an onboard compressor. Have used the airbags to adjust 5W height a bit, especially when the jacks didn't work.
BillMoRex&Princess
Fulltiming since 8/93
2008 35 SB/ 2006 Chev Duramax
Heat84
Oh yes and my best buddy Lacey my dog
Cardinal Owners: 29ft
many add on like fireplace, central vacuum wet suspension just to name a few
Post by Heat84 »
:o :shock: :? :? :? :roll: Ok I'm black and blue ! ! help me out here what are TORSION KEYS ? ? ? ?
MIKE & BRENDA
29'WBL FIFTH WHEEL
ALL THE WHISTLE AND BELLS
Full time summer
Hi Mike, I think it has to do with torsion bar adjustments.
Super Duties don't use torsion bars.
