Performance Chip programmers
Has anyone out there used the Hypertech chip programmer? I am looking to get one for my 2004 Dodge 3500 SRW and before I spend that kind of money I want to know more about it (user friendly, performance increase, mileage increase, bad side effects, etc).
Thank you in advance,
Bob
Bob
Re: Performance Chip programmers
Do you have an auto? If so be careful I have said it many times since I have been there myself "for every action there is a reaction" I have owned 5 CTD put stage 1 injectors in the one that was an auto all was fine until I hooked the 5er behind it and there went 2k for a tranny upgrade. On one of my 6 speeds put stage 3 injectors and a edge ez on it yep southbend cono fe clutch was next then I had a friend that made me a 4 low kit that would not lock in the front end so I could back up since there was no slipping the clutch without rattling the doors off the truck. I know many run with fueling and timing boxes and alls I am saying is be careful.
Just like Mike said, if you "chip it" you WILL find the weak point. I have used the chips in Ford 7.3 diesels, the only one that did not cause trans and torque converter problems was the standard shift F350. They advertise fuel milage gain but I never saw any, but if you are looking for power and you use it how could you get better milage? I would not recomend any engine mods for anyone that hauls a heavy load. I will say that the large exaust and intake mods did not accomplish anything other than lightening my wallett, but not enough to help my fuel milage.
I agree with the comments, don't chip it! I HAD a Ford 7.3, spent a lot of money and time installing chips, air intake, exhaust and in the end the truck was not that much better. In fact within weeks I had nothing but computer problems and the tranny shifting was never right. The dealer had to re-burn the computer. I set it back to stock and sold the trunk, I was that disappointed!
- Shields
- Cardinal Owners: 31 RK LE
Well, jeez, I missed out on all the fun.
I chipped my 5.9L CTD, I did notice a mileage increase ( a whopping 1 mpg) and better mid RPM torque. I really enjoyed it on light to medium loads on flat ground. However, in the hills (like the Rockies), I had to set it to stock because the turbo temp shot too high and not wanting to burn out #6 cylinder I did not exceed 1250 degrees where the factory limit is. And, after they replaced my fuel pump (warranty issue with that model) and put it in the fuel tank I noticed not much gain from the Bully Dog. Now that I have the 2009 CTD with the bigger engine, I will not attempt to chip it. Enough power there to do the Rockies already and obviously I am not worrying about mileage now.
Check on the Smarty for your Dodge. Hypertech is not one of the main line upgrades for a Dodge/Cummins. Have you been to the Turbo Diesel Register site? Lots of info there. Although the 48RE is slightly better than the 47Re in the 2nd gen trucks, too much power will do it in also.
Remember that you become your own warranty station!
- Shields
Past that stage now, over 100k
New CTD, 2009, doesn't need a chip
I was thinking of adding a chip, but after reading this I think I best leave things just as they are.
If you want a truck that is really fun to drive then use a programmer and return to stock when towing. These things will fly when empty and using a chip and doesn't seem to hurt thrm when running empty. They are a Hot Rod.
