Timbren Suspension Systems
- teallen
- Cardinal Owners: 2012 3030
- Skype ID: thomas.allen511
I am trying to decide on how to enhance my truck suspension, air bag, another spring, or timbren system. Has anyone dealt with the Timbren Suspension system? Went to a dealer today and he discussed the three options, recommending the Timbren.
Tom and Judy
2018 RAM 3500
9 grandkids (keeps us busy)
Rallys attended - 17
2019 Camping Days- 7
2018 RAM 3500
Re: Timbren Suspension Systems
Went and read up on the Timbren. It replaces the existing foam filled rubber snubbers with hollow rubber snubbers. They must be longer than OEM to contact the axle to preload the snubber. As weight is loaded or front axle is jolted (Michigan roads), this new snubber resist the load. I have the Firestone air bag in the rear and keep it a 5# empty and 24# hitched up. Would this system take up the addition pin weight without me having to add air? I might look into adding the front system to help keep my teeth out of the steering wheel.
- Skype ID: bill.bopra
I had Timbrens on my old Dodge and I wasn't real happy with them. They worked to level the truck when the camper was hooked up but the ride was pretty rough. I think they helped with any side to side sway but they didn't give much when driving on bumpy roads.
The Timbrens ride about a 1/2 inch above the axle when the camper is not hooked up and when you hit a bump and the axle goes up and hits them it's like hitting a brick especially in the winter.
If I ever feel the need for some type of helper I think I'd choose the air bags.
Bill, thanks. I was wondering if there was a gap or were they preloaded against the axles.bop11 wrote: The Timbrens ride about a 1/2 inch above the axle when the camper is not hooked up and when you hit a bump and the axle goes up and hits them it's like hitting a brick especially in the winter. Bill
- gmarker
I'm using the Firestone airbags and have been very happy with them. I like being able to adjust the pressure to whatever load I'm carrying and when I am not loaded I don't have to feel every little bump in the road.
I did the all research on the various alternatives, from 1 ton overload springs, which would have upgraded my TV to a 1 ton per Dodge (the only difference between a 2003 2500 and a 3500) with a change of door sticker to after market overloads to airbags and timbrens. I settled settled on timbrens. They were the cheapest and the least painful alternative with all the hype filtered out for the various alternatives. Simple to install. All that was necessary was removing the existing jounce bumpers and installing, about 15 min. Unloaded, they are about 1" above the axle housing. Loaded with the fiver they sit on the axel with the truck LEVEL and greatly improve the reaction of the suspension over unloaded; no excessive rearend hop on rough roads unloaded either. BTW, they are rated at 6000 lbs.teallen wrote:I am trying to decide on how to enhance my truck suspension, air bag, another spring, or timbren system. Has anyone dealt with the Timbren Suspension system? Went to a dealer today and he discussed the three options, recommending the Timbren.
Bottom line is they worked for me, but results may vary.
Cheers,
Merv
A friend put them on his Chevy, and removed them after a year and install air bags. Chris
