Low boost code
Low boost code
Well my luck got a check engine light today for low boost. Called onstar to confirm the code PO299 and its for low boost, cleared the code with my insight to see if it would re throw but of coarse no it did not and the dealer will not look at it until it does Got on diesel place to see if anybody else is having problems and there are about 6 other 2011 trucks with the same problem. Most of them set the code while towing mine set in a parking lot GM is aware of the problem and needs to re write the software to fix it but wont have it until after the first of the year. Sooo for the first time in my life im hoping to set a code so I can take it to the dealer to have them look at it and make sure its not a bad ECM or actuator sensor, kind of hope it is so i dont have to wait for a software fix.
Re: Low boost code
Maybe it draws the intake air from the truck bed and the new cover is restricking flow? Chris
Re: Low boost code
It sounds like GM has a fix and I doubt that the dealer will do anything until the fix is applied first.
Re: Low boost code
Well the problem is some of the people with this problem have had to have the ecm replaced others a sensor if they cant find a cause then you wait. My boost is all over the place and my idle is up which is the symptoms everybody is having. I am going to call the dealer and hit them up with a low power issue so they will take it and check it out.
Re: Low boost code
What kind of reading are you getting on the edge insider I am not sure what you mean " low boost" Is there no turbo boost when you need it for power
Re: Low boost code
Torben looking at the Edge Insight my boost is all over the place right now. As you know this gauge was not made for the LML trucks but for the most part it is reading correctly for the items i need. When I go into regen my boost will go to the negative side when i let off the throttle which has been normal since day one, but I just came out of regen and still seeing negative to low boost it is at -.08 when at idle and under normal driving sometimes wont go over 1.5 lbs of boost then will jump to 3 to 4 lbs like normal. I can feel the lack of power to go along with these readings, then it will jump to normal, my idle is also high when this is happening which is another symptom with this problem people are having. I think under sustained boost like on the freeway it is going to trip a code again will find out today going out to the trailer then if it does not trip will tow the trailer a few miles which is when most of the people are noticing the problem. For what ever reason mine went off in a parking lot so do not understand that since the code is set if you are running 7 lbs of boost less then what the computer thinks you should run.
Of coarse i cleared the code and the dealer wont look at it until i have a code since now a days techs cant seem to fix anything without one But I am going to talk to the dealer on Monday and complain about low power which will make them check the items needed like the actuator sensor and the ECM
Re: Low boost code
Well drove over 100 miles today 20 of which were towing the little girl all was well boost is back to normal so I guess I have to wait and see if it will do it again.
Re: Low boost code
That's too bad you couldn't duplicate the problem. Intermittent problems are the worst. It's happened to you and others so you know it will be back it just a matter of when and where.
Re: Low boost code
Mike Clay wrote:Torben looking at the Edge Insight my boost is all over the place right now. As you know this gauge was not made for the LML trucks but for the most part it is reading correctly for the items i need. When I go into regen my boost will go to the negative side when i let off the throttle which has been normal since day one, but I just came out of regen and still seeing negative to low boost it is at -.08 when at idle and under normal driving sometimes wont go over 1.5 lbs of boost then will jump to 3 to 4 lbs like normal. I can feel the lack of power to go along with these readings, then it will jump to normal, my idle is also high when this is happening which is another symptom with this problem people are having. I think under sustained boost like on the freeway it is going to trip a code again will find out today going out to the trailer then if it does not trip will tow the trailer a few miles which is when most of the people are noticing the problem. For what ever reason mine went off in a parking lot so do not understand that since the code is set if you are running 7 lbs of boost less then what the computer thinks you should run.
The low power condition can be easily rectified by running to the nearest FORD dealer! LOL
Re: Low boost code
Why do they need one towed back to the factory
Re: Low boost code
pretty good, pretty goodMike Clay wrote:Why do they need one towed back to the factory
Re: Low boost code
