Low boost code
- Illona Lucas
- Region Leader
- Cardinal Owners: 2008 35 ft SB
Re: Low boost code
Now now fight nice children, and by the way just what do you all think is wrong with Fords? I really love mine.
Bud and Illona
2008 35SB W/Trailair
Six Point Level Up System
2006 Ford F350 Diesel Crew Cab
Air Lift 5000 Air Bags
Re: Low boost code
Yep, some peoples kids.Illona Lucas wrote:Now now fight nice children.
Re: Low boost code
Illona Lucas wrote:Now now fight nice children, and by the way just what do you all think is wrong with Fords? I really love mine.
They all find nutin wrong with the FORDS! I just started some fun, and I knew exactly what was gonna happen
Re: Low boost code
At my broken trucks expense
Re: Low boost code
Better yours than mine.Mike Clay wrote:At my broken trucks expense
I don't have a warranty.
Re: Low boost code
Just want to get it fixed dont want need this hanging over me with all the trips next year. Probably will need to wait for the re flash after the first of the year. grrrr.
Re: Low boost code
I know whay you mean about that worry bead. To be honest with you Mike, Diann and I had a sigh of relief when we got home from the two rallies. With our history of engine issues, the truck performed flawlessly.
Re: Low boost code
Mike if others are having the same issue GM will figure it old shortly and have a fix. I also have a code reader and reset a code on DW's Buick Rainier. Mistake! Dealer said because I had reset the error they could not trouble shoot the issue. Had to wait for the error again. Each new gen engine/truck will have a few issues. Remember "YOU LOVE YOUR NEW TRUCK!" Chris
Re: Low boost code
Oh i do in fact its the best truck i have ever had. All the big three are having problems with setting codes there are WAY to many sensors in this truck. Hopefully it will set again soon it has until the end of Feb. before i start towing again. GM is suppose to have a software fix right after the first of the year. May have to wait until the next regen since that is when it did it this time, right after the regen was done.
John I know what you mean i felt the same way about my trailer
Re: Low boost code
Mine was a bad turbo vane position sensor. No longer covered under GM warranty. Sensors were dropped a couple years ago. May get a partial "goodwill" refund. ($810 out of $1000)
Problem could also be a bad MAF sensor according to others. Apparently, this code shows for several different issues. They had to spend some time troubleshooting mine. I will say the fix has worked all 10,000 miles so far.
Re: Low boost code
Well if that is the case we shall see who pays. Did you have intermittent problems or when it was bad it was bad.
Re: Low boost code
You won't have any problems in that regard since your truck is only in it's first year.Mike Clay wrote:Well if that is the case we shall see who pays.
Re: Low boost code
When it went bad, it went bad. Kept clearing the codes and it would run 10-15 minutes and come back.Mike Clay wrote:Well if that is the case we shall see who pays. Did you have intermittent problems or when it was bad it was bad.
