Air Lift Bags
Re: Air Lift Bags
I use 20# but I don't have near 2600# tongue weight.
paul7x57mm
Cardinal Owners: 2004 33 CKT
Skype ID: paul7x57
Re: Air Lift Bags
Post by paul7x57mm »
I use about 27 to 35 lbs with 2500 pin weight. Just enough to level when hitched.
Paul and Anita 2004 LX33 CKT, 2006 F-250 PSD 6.0 Supercrew shortbox, Airlift Bags, Drawtite w/slider & Moryde
Nights camping in 2011: 7
Nights camping in 2010: 21
samthenuke
Cardinal Owners: 31-2BHLE
Re: Air Lift Bags
Post by samthenuke »
I had air lift bags on my previous 3/4 ton Chevy. I haven't decided yet if the new 2011 Chevy Duramax/Allison will need them. I will need to hook up and go for longer than from the winter storage facility to decide. :thumbrt:
Re: Air Lift Bags
I have only towed around 2,400 miles with mine but it hardly touches the over loads so im going to hold off for now.
Re: Air Lift Bags
They shouldn't be needed on a 1-ton. If I had it to do all over again I would replace the 2" blocks between the springs and axle with the 4" blocks that come on the F-350 and not use air bags.
Re: Air Lift Bags
Well my 1 ton 2004 Dodge did it would sink down 4 inches and that was with the 29 rkle
Re: Air Lift Bags
Yep, I drove mine for about 5 months before I put the air bags on. I just wanted another 1-2" to get the level right were I wanted it. If I had the 4" blocks, instead of the 2", it would have been the perfect height.
paul7x57mm
Skype ID: paul7x57
Re: Air Lift Bags
I towed my trailer last weekend with 40 lbs in my Airlift and it was too stiff. I lowered the pressure to 30 and it rode good.
PapaJoel55
Cardinal Owners: 30QSBLE
Re: Air Lift Bags
Post by PapaJoel55 »
i put the timbren system on mine and it works Timbren We just brought the bird to tenn. and it handled the best it has ever been.they wont go flat and they handle an extra 6,ooo lbs. and they were very affordable.
Joel
Joel and Toni
2008 30QSBLE
2008 Silverado 2500HD Duramax
gmcbride
Cardinal Owners: Cardinal T31RKT
Re: Air Lift Bags
Post by gmcbride »
My setup uses a Firestone with compressor that I manually adjust. Generally, 10 pounds when empty, 45 when towing. My TT has a tongue weight of 1,400#. System works great. I also ran the tubing to the license plate. It takes the place of the top right screw. Should the pump stop I can still add pressure and no one kinows it's there. Cheers! :))
George & Sandie
'06 T31 RKT TrailAir Equa Flex
'12 Dodge 3500 dually
'15 Victory Cross Country Tour
