Better Mileage
Better Mileage
I’ll be the first to admit that I’ve not the most mechanically minded, so please explain in simple terms.
We have a 2008 Chevy Duramax. We have about 50,000 miles on it and it’s done a great job of pulling our rig. We would like to increase the power and also the mileage.
I’ve read about adding “chips” also I’ve read about some different products that Banks makes to improve what I’m asking for. From your experience what is a good way to go to meet our objectives? What works, and what doesn’t?
Re: Better Mileage
IMO they're all snake oil. Just be as easy as you can be with the throttle and drive at a constant, and slower, speed.
bfast54
Re: Better Mileage
Post by bfast54 »
Well, put simply.....you Cannot increase power, and Mileage. :-B If you increase "power", you will use that for a " rush", because you will be stomping the "Go pedal" more :ymcowboy: (been there, done that in my younger day's) \M/
Now, you can increase efffiency, by adding things like "Banks" intake, exhaust, power chips....etc................... BUT................you have to drive a lot of miles , to relise the "savings"
Say you spend $1500-$2500 on Improvements............................and get , oh say 1 MPG improvement. Now, even 1 MPG is fantastic , if you are talking 9 MPG (10 percent improvement)............but, how many miles are you going to have to drive just to "pay" for the improvement , and then ...start saving money, by the increased mileage.
Now, add to the problem, with the U.L.S.D. ...............there is simply less POWER avail. in todays fuel. They cleaned up the Sulpher, but it has less "cetane", I.E. Less bank=Less power.
So, there it is in a nutshell.......................it costs a lot of money, to save just a bit of money. (not at all like the old days), vehicles were so in-efficient you added headers, intake, better air filter, etc............ you got better mileage (if you kept your foot out of it) :))
Todays vehicles are tuned, Fuel injected to be so efficeint, about all you can really do , is make improvements to make more use of the powwer avail..............BUT, if you really stomp it, you will use more fuel.
THe Power chips, dial in , etc .............. is to make more power, so when you need it (like passing), you have a reserve ...when you mash it.
Does this make sense??? Help any ???
Re: Better Mileage
If my first priority was to increase power what would you suggest? I see you can't increase milage and power ^:)^
bfast54
Re: Better Mileage
Post by bfast54 »
Well, friends who have Dura-max's have "Chipped" thiers, and love the results. (one of my friends even got a ticket from the Lansing Police (Mi) ) for "Smoking " his tires with his 2500 HD Duramax :)) ...............He said he got carried away with all the power, and just kept turning it up.
So, I would prob. go with a "Tuner" box. I believe Mike could tell you about the one he used to have.(dont know if he still has it)
Juice, Edge , are the names I have heard them say. My cummins has a old fashioned fuel plate, so it has been " Tweaked "(before I got it, of course) ;) I did dust a corvete once .......(at the launch)..............................He was surprised :-O :-O 8-X
Torben
Re: Better Mileage
Post by Torben »
I remember that day =))
bfast54
Re: Better Mileage
Post by bfast54 »
Torben wrote:I remember that day =))
At least you are a sport about it . :thumbrt: =)) =)) =))
Re: Better Mileage
I had two programs in my 2005 Ford 6.0L. One for economy (2-3mpg improvement) and the other for more towing power. The economy tune just leans it out and it actual made 25 more hp and 45 more tq. The towing tune added 75hp / 125tq with a 1 mpg cost to OEM tuned mpg. That was a $800 cost for the sct tuner and 3 hours on a chassis dyno. A good tuner will find you the best economy and power. Then you need to drive it conservatively. That is where you'll make the biggest difference in mpg.
Re: Better Mileage
Well if you want to be your own warranty station go ahead but I sure would not do anything. My 08 had all the power I needed for towing our 3150 at 14k and got an average of 11.6 mpg doing it.
Re: Better Mileage
Good to know, thanks for the help -- I think I will leave well enough alone.
dieselfreak21
Cardinal Owners: 2003 Cardinal 32 LX
Re: Better Mileage
Post by dieselfreak21 »
If you want to see a mileage increase and power increase at the same time you want performance tuner that has the ability to increase timing. Due to EPA concerns they retard the timming of the injection event to control emissions. This in turn causes them to make up for the lost power by increasing the duration of the injection event using more fuel. Most of the performance tunners change both timing and injection duration. So the boxes are not snake oil and I wouldn't go with Banks. The air intakes and such usually don't yield any power or fuel economy. They can help lower EGT and help with spool up if done properly which help you add more fuel for more power and give slightly better throttel response as the turbo can spool faster.
If you really want to add fuel mileage on EPA engines you really need to remove the EGR system and DPF and then a tunner that puts more realistic timming curves.
With my truck at the factory power the best mileage I could ever get running 70-75 empty was about 16-17. Once I put a tunner on it and adjusted the timming I know get consistant 19-20 empty. Towing with out the added timming was consistant at 10mpg with the rv. With a timming program with added power for towning but with out pushing the limits to far I consitantly see 12mpg + unless fighting a head wind. This is driving 65-70 mph. These speeds keep the engine in it sweet spot. Going slower or faster has decrease fuel mileage. Faster for obvious reason, but slower due to more lugging and down shifting.
Now doing all of this isn't that cheap. A good box will set you back 8 bills and epa equipement removal will be another 5 bills. But removing the epa stuff will help with engine longevity as well. Timing does increase cyclender pressure and does raise piston crown temps a little more but if you drive by your EGT gauge you shouldn't have a problem.
Re: Better Mileage
Dieselfreak
That is a lot of information and a person would have to be very serious about wanting to increase the power and mileage to make those modifications and spend that kind of money. Is that cost if you do it yourself or have it done?
There is another problem for anyone from California removing your EPA equipment in California would cost big time because they are now making you smog your diesel and what is the first thing they look for :?: You guessed it modifications that bypass the EPA smog devices.
Re: Better Mileage
I'd be very careful as I believe removing the EGR and/or the DPF is illegal and changes to the engine setting could jeopardize your warranty.
Re: Better Mileage
Rob & Cathy wrote:I'd be very careful as I believe removing the EGR and/or the DPF is illegal and changes to the engine setting could jeopardize your warranty.
You would carry the warranty once you did this.
Re: Better Mileage
At the very least.
