Removing Hitch From Truck Bed
Now that my son has moved away I don’t have anyone that can help me take my hitch out of the truck bed. I was wondering if anyone has built or bought a lift or crane like device that you use? I was thinking of adding a pulley or come-a-long in the rafters of the garage, but I’m not sure the rafters could hold the weight.
My present hitch weights about 80 pounds, not to bad. But I'm thinking of getting a TrailerSaver air hitch that weights about 150 pounds.
- EAW
- Skype ID: eaward49
Re: Removing Hitch From Truck Bed
A friend of mine uses a engine hoist to remove his and move it around.
- sew2bhappy
We use an engine hoist, too. Makes it easy to move the hitch around in the garage. I believe DH got his at Harbor Freight.
2013 Cardinal 3030RS
1998 Volvo VNL610
2009 SmartCar-Bitsy
Nights out in
2018 - 93
...2015/16/17 - full time
...2011/14 - 719
National Rallies - 6
Regional Rallies - 10
FROG - 4
1998 Volvo VNL610
2009 SmartCar-Bitsy
Nights out in
2018 - 93
...2011/14 - 719
FROG - 4
I used a come-a-long to get my trailair hitch out of the box and paint it. I know what you mean I depend on my son helping me lift heavy items but he is not around much anymore. My hitch comes apart in three sections but the base is heavy.
I help my hubby get the hitch out and into the garage. Once he gets it on the tail gate, I help him lift it down and carry into garage, same way putting it back. LOL He say's I'm a girly man. Guess I am use to lifting heavy things, use to lift boxes of quarters all day long, those are heavy.
Mike what kind of paint did you use on your hitch when you repainted it.
Mike what kind of hitch do you have?Mike Clay wrote:I used a come-a-long to get my trailair hitch out of the box and paint it. I know what you mean I depend on my son helping me lift heavy items but he is not around much anymore. My hitch comes apart in three sections but the base is heavy.
Jim If you take a chain and loop it around two trusses and attach the come along to the chain the rafters will support the weight of the hitch.
we have many times just left it on the front of the trailer. Just pull the pins and press extend We used to pull engines from the rafters, the key is to distribute the load, We put a driveshaft across 4 or 5 rafters and hung a chain thru the ceiling. What size rafters/joists do you have?
They're truss rafters made out of 2x4's
Just use exterior spray paint
I have a Reese 20k select series hitch
- dpalmer
- Cardinal Owners: 2018 3456
I placed a triple 2x4 across the trusses and a come-a-long then lower it to a base with casters and roll it away. My Curt base is too heavy to lift by hand. Looking at a 120V power hoist.
Dave & Karen
2018 3456
2021 F350 XLT, 4x4 Dually
Full-time as of 10/1/2016
2018 3456
I used an engine stand with the Super Glide. I haven't moved the new one yet. Its a 3 piece unit so its should be easier.
- bayoubengal
My father-in-law does the same thing as Matt. Just leave it on the 5th wheel and pull the pins. He never leaves it in the truck and has no problem re-attaching.
Vince & Kim
2008 31RKLE
Nights Camped:
'02--74 '06--122 '10--24
'03--59 '07--47 '11--44
'04--83 '08--98 '12--76
'05--99 '09--84
2008 31RKLE
Nights Camped:
'05--99 '09--84
one of the things I like about the curt Q5 hitch it comes apart in 2 pieces the head unit comes off the base so you are only lifting 30-40 pounds at a time.
Not that it matters now but I'M not getting any younger
- Parno
- Cardinal Owners: 2005 Cardinal a 29WB, 5th Wheel. 3 weeks later a 2008 Dodge Quad Cab with Smoke Motor.
3000 Boliy Generator, 500 watts of solar
1000w Invertor, 2 Golfcart T-105 batteries, Bogart 2025 Charge indicator
Moryde ISR suspension (Best thing we;ve done!) - Location: Escapees Fulltimer
- Contact:
bigbunkhouse wrote:we have many times just left it on the front of the trailer. Just pull the pins and press extend We used to pull engines from the rafters, the key is to distribute the load, We put a driveshaft across 4 or 5 rafters and hung a chain thru the ceiling. What size rafters/joists do you have?
My SuperGlide will not come out using this method. too heavy and it hangs on the rear pins. Going to be a problem in the future as we will not have a stick house;-(
Peter & Anne-Marie Arnold
Member of Escapee's
National Camping Travelers, A Masonic Camping Group
2005 Cardinal
2008 Dodge RAM W/Smoke Motor
Somewhere, Texas
Member of Escapee's
2005 Cardinal
Somewhere, Texas
