Hi - I've been taking a peek at the new Chevy trucks. I see there is an option for 5th Wheel wiring in the bed of the new trucks. Here is my question: In the trucks that have this option, there isn't a plug in the bed. Is the wiring routed and a plug just needs to be added? If so, where exactly is it? Thanks for enlighting me.
- Jim
5th wheel wiring in new Chevy trucks
- JimOMartin
- Cardinal Owners: 2007 33TBH
Jim & Cathy Martin
2007 Cardinal 33TBH LE
2011 Chevy 3500HD D/A 4x4 LTZ Dually - Black Bart (AKA - Black Butt)
Re: 5th wheel wiring in new Chevy trucks
There is a plug on the bumper but for the bed the wire is rolled up behind the driver side of the cab. You need to install your own plug in the bed where you want it.
- JimOMartin
Is it long enough to get the receptacle to the back of the bed and I'm assuming sheet metal would have to be cut? Just wondering.
- Jim
- Jim
Jim & Cathy Martin
yes its long enough I have mine back under the last stake pocket hole. Just make sure you seal the plug well so water wont get in. We used a hole saw to put mine in.
I put my plug in the middle right by the handle on my hitch. I can plug it in and lock the hitch all from one spot.
Being short I need a step stool, (sorry Don Wilson) a step ladder to reach both.
- bayoubengal
Mike, I think the wire is still rolled up behind the driver's side of the cab, but the RV dealer installed the plug for the trailer in the bed like we all have. I'm thinking they didn't know about the wire behing the cab and just tied it into the plug wire on the bumper. Need to remember to make a closer check to see just how it is wired.
Vince & Kim
2008 31RKLE
Nights Camped:
'02--74 '06--122 '10--24
'03--59 '07--47 '11--44
'04--83 '08--98 '12--76
'05--99 '09--84
2008 31RKLE
Nights Camped:
'05--99 '09--84
Yes the wire is behind the cab on top of the fuel tank. The dealer knew and so did I from my 08, Olbird and I wired it ourself did not have a dealer do it. If you look on the cap of the one that is in the bumper it tells you what wire goes where.
