First tow
Re: First tow
Rob, is this the first you've gone across the scales?
My total trailer weight looks like this on average:
Pin weight - 2500#
Axle weight - 10181#
Total (with 3/4 tank of fresh water) 12681#
Well within the trailer GVW.
Pin weight - 2500#
Re: First tow
LOL, no I used the same scales years ago and if I remember the pin weight was as 2K and the trailer axles were under 10K.Chief409 wrote:Rob, is this the first you've gone across the scales?
I may be exceeding my trailer GVW. I'll check the placard when I get a chance.
Re: First tow
Your right you better put that tubo on a diet, you are running way more weight then my 06 did and Susanna thought it was a bomb shelter.
Re: First tow
I think you're right Mike.
I checked and the GVW of the trailer is 12190#. Oops!
The axles are 5200# each so I'm OK there, barely.
Re: First tow
Interesting comparing your truck to mine. Will be good to compare Jeff's weights to mine IF he ever gets it.Rob & Cathy wrote: Truck GVW: 11500#
Without the trailer:
Front - 4960#
Rear - 3560#
With trailer:
Front - 5020#
Rear - 5900#
Trailer axles - 10280#
Pin weight: 2340#
Total trailer weight: 12620# with half a tank of freshwater.
Yikes, the trailer needs to go on a diet!
Re: First tow
Sheesh mine is 5,100 front and 3,900 back
Re: First tow
Mike, I'm surprised that you're truck is heaver than John's DRW truck.
Re: First tow
AUX TANK FULL?? I thought maybe Mike put down 5100 for the front when it was really 4100. Then the tank hit me!!!
Re: First tow
I think you're right Chris. Last April Mike's truck was 8600# and now it's 9000#.
Re: First tow
Yep its the tank
Re: First tow
No DEF used in 1600 miles, over 13 miles to the gallon towing, I still think you need to check under the hood and find out if Ford put their secret experimental engine in your truck.
Re: First tow
LOL, that works for me.Olbird wrote:over 13 miles to the gallon towing, I still think you need to check under the hood and find out if Ford put their secret experimental engine in your truck.
In the Cardinal world we have a relatively light trailer at 12000+ pounds. With 3:55 gearing and 18" wheels it may just be the ideal combination.
That surprised me too George. It may be that I was doing something wrong. In hindsight I have to wonder if the pump was dispensing the DEF to quickly for the relatively small tank. The reason I say that is because this was the first time I had been to the truck pumps and when I filled the diesel tank with 28 gallons it took just seconds. I have never seen a pump dispense fuel so quickly. From what I've seen on You Tube the DEF goes into the pickups rather slowly. Anyway that's why I'll wait for the DEF message before attempting to fill the DEF tank.Olbird wrote: No DEF used in 1600 miles
Re: First tow
WHEN I get the new truck, hopefully around the end of next week, I expect it to weigh a bit less then what the '09 weighs when I get it fitted out unless all the Lariat bling makes up for the lighter engine!Travelers wrote:Interesting comparing your truck to mine. Will be good to compare Jeff's weights to mine IF he ever gets it.Rob & Cathy wrote: Truck GVW: 11500#
Front - 4960#
Rear - 3560#
With trailer:
Front - 5020#
Rear - 5900#
Pin weight: 2340#
Re: First tow
If you are not using DEF and not getting any trouble codes that is great, that would work for me but how can you sleep at night knowing you are polluting the earth with your nasty NOX
