WHAT MAKE OF REPLACEMENT BATTERY-TRUCK
jerry
Cardinal Owners: 06 30' WBLE
Contact:
Post by jerry »
i have on 03 ford power stroke, 7.3, and the batteries are starting to play out. My batteries are from wally world and are almost 3yrs old . Do any of you have a make of battery that you have had good luck with.
Jerry
06 wble
03 Powerstroke, 7.3
BMullins46
Re: WHAT MAKE OF REPLACEMENT BATTERY-TRUCK
Post by BMullins46 »
I had real good luck with the factory battery that came with my V10 Excursion. Also Interstate. Just be sure to replace both batteries at the same time.
bigbunkhouse
Cardinal Owners: 2007 362BHS
Post by bigbunkhouse »
I have said many times...we have 16 ish powerstrokes we plow with . They all have Electric Hydraulic plows and 7 have electric hydraulic dumps also. We run Group 65 Batteries from Napa in every one of them, they have 1080 ca each and last 5 to 7 years in our harsh duty. They have a pro rated warranty and all come with a sticker on one end that says for example "B8" which says it was made in February of 2008, when I buy batteries I check the "code" to make sure im getting newer batteries. As a point of interest, the FICM on the 6.0 needs 48 volts to operate properly, if even one battery is weak you can damage either the FICM or other related parts. I recommend checking the load ability every fall and the charging system as a whole at the same time. One mistake I saw the guys at the parts store making was checking the batteries as a pair, DONT DO IT...you must disconnect and check individually.
:-B :-B
I got the same deal on both of mine from the Dodge dealership that Interstate offered so check out both!
bfast54
Post by bfast54 »
bigbunkhouse wrote:We run Group 65 Batteries from Napa in every one---------- when I buy batteries I check the "code" to make sure im getting newer batteries. As a point of interest, the FICM on the 6.0 needs 48 volts to operate properly, if even one battery is weak you can damage either the FICM or other related parts.
:-B :-B
Ummmmmm, Am I missing something here?????? Even if you 2....X...12.....................................2 batteries, at 12 volts each?????????........How do you come up with 48 volts, not being smart, just wondering what gives?? @-) @-) Does Ford do Magic with their ECM,s :-?
I know with my cummins', the electric air heater Gobbles up the volts............................it will slow down the engine, when they kick on :shock: :shock:
bigbunkhouse
the batteries are parallel netting twice the amps at 12 volts. Its the same way you can get 45,000 volts from a coil on a 12 volt system. Just very hard to build the voltage with one lame battery even with capacitors, step up coils or whatever hocus pocus they use.(transformer)
Samsbird
Skype ID: yes
Post by Samsbird »
I just replaced the original batteries on my 06 and I went back with Motorcraft, better battery and no more expensive than the ones that the parts houses carry.
Randall
2009 35sbq fifth wheel
1970 (Boss 302)
