New Hitch????
wild acres
New Hitch????
Post by wild acres »
Just bought a new 2012 F250 and was wondering if anyone who has gotten one has had to buy a new hitch??? Can't use the rails from old hitch due to Ford putting the new rails under the bed of the truck. (Has rubber plugs in bed, remove plugs and set new hitch in. Talked to RV dealership and said the new Fords will require a different hitch, to connect them to the truck, I think from Reese. Thanks guys in advance. John
Re: New Hitch????
Congrat's on the new Ford. :thumbrt:
Re: New Hitch????
Congrats on the New Ford John. Two people who bought new Fords are Chief409 and Rob and Cathy they will probably be on later and give you their input.
Re: New Hitch????
Congrats on the new truck. I am very happy with mine and I am sure you will be too. My Ford is a short bed, so it did not have the factory option. I believe that your truck is set up for the Reese series that does not require the rails.
Re: New Hitch????
Congratulations on the new truck John, you'll love it and have a BSEG while driving especially when towing.
Like Randy, I didn't get the factory installed hitch rails and they are for the Reese Series hitches. I suspect other hitch manufactures will come out eventually with adaptors for the Ford rails and if I'm not mistaken Jeff ordered his new Ford with the factory rails and had to get adaptors for his old Reese hitch.
Re: New Hitch????
Almost afraid to ask what is bseg
bfast54
Re: New Hitch????
Post by bfast54 »
Mike Clay wrote:Almost afraid to ask what is bseg
Mike..................sent you a P.M. :d
Re: New Hitch????
Big S**t Eating Grin :d
Double D's
Re: New Hitch????
Post by Double D's »
Just WHERE is that soapy washcloth!!!!!!!!!!!!
Double D's - Dennis and Donna
Rallies - 20
Days out in 2015- 145
Days out in 2014 - 71
Days out in 2013 - 187 Alaska
wild acres
Re: New Hitch????
Thanks guys and gals for response's, i am enjoying the bseg. I have a drawtite hitch, so I don't think there is a addapter plate for it, talked to RV dealership, said I'd have to order the elete hitch from Reese. I also have a short bed, so they think 1600 for a slider, guess if I can afford a new truck, I can afford a new hitch, said they would give me a trade in allowance for old hitch. We'll see. Again thanks, John
Re: New Hitch????
Im calling Cathy geez Rob
Re: New Hitch????
Mike Clay wrote:Im calling Cathy geez Rob
I know, I know. :oops:
Re: New Hitch????
wild acres wrote:Thanks guys and gals for response's, i am enjoying the bseg. I have a drawtite hitch, so I don't think there is a addapter plate for it, talked to RV dealership, said I'd have to order the elete hitch from Reese. I also have a short bed, so they think 1600 for a slider, guess if I can afford a new truck, I can afford a new hitch, said they would give me a trade in allowance for old hitch. We'll see. Again thanks, John
There an adapter kit for the Signature hitch that replaces the locking lugs with longer ones that I used with the Elite truck mount Ford is using.
Here is a link to the store I bought the adapter kit from: http://www.etrailer.com/p-RP58419.html
Donpop
Cardinal Owners: 2008 Cardinal 34QS
Re: New Hitch????
Post by Donpop »
John:
If you need a new hitch then getting the proper one to fit your under bed rails would probably be the way to go. However, for those of you that want to order the Ford under bed rails(which includes the 7-pin receptical in the bed) or have bought off the lot with this option, there is an alternative. When I special ordered my new truck I also ordered the hitch prep kit because I though it was a good buy. However, I had an almost new 18K hitch with a custom built bed-saver(not a Reese) that I did not want to give up. I ordered a TrailSaver Ford Under Bed Adapter Plate from Hensley that let me mount my present hitch. You just fold out four levers and the whole assembly lifts right out. Its kind of pricey but I'm at the point in life I don't worry about that anymore. You can google "TrailSaver Ford Under Bed Adapter Plate" and see the simple installation. You end up with the same smooth bed floor just like you would with the Reese hitch. Don
2008 Cardinal 34QS
Kodiak Disc Brakes
Chief-e9
Cardinal Owners: 2010 Cardinal 3100RK
Re: New Hitch????
Post by Chief-e9 »
Being new to the 5th wheel world I've only owned one style hitch. It is the B&W Companion. It has worked well for me on my long-bed truck. I like the ease of connecting and disconnecting the RV as well as the ease in removing and installing the hitch. I'm not sure if they make one for a short-bed. I added this in case you for some reason decide to go with an entirely new system instead of your current one. Decisions, decisions!
Vickie (Retired RN), Roy (Retired AF) Baxter the Shih-Tzu (RIP Nov 2014) Bella Mae the Shih-Tzu (RIP Aug 2021)
2011 Ford F-350 Long Bed Crew Cab Diesel
