Decided to keep 2006 F350
Re: Decided to keep 2006 F350
sorry to hear that Rich, If you need a dually for a few I know where you could borrow a nice v10 for a while! Thank god for great friends...have a safe weekend
Matt
Matt
Bummer Rich. At least it happened close to home and you were able to continue your trip thanks to friends.rpfan wrote:Looks like the BRAND NEW oil cooler has failed .
- Skype ID: yes
Sorry about your problem, I hope it is something simple and you don't have to go too deep to figure it out. Just brainstorming here, is the fan coming on, did you install a new waterpump during the rebuild? Keep us posted.
Randall
Randall
2009 35sbq fifth wheel
1970 (Boss 302)
1970 (Boss 302)
- Region Leader
New;
Water pump
Radiator
Fan clutch
Thermostat
Oil cooler
1 new injector
ARP studs
Black onyex head gaskets
Valve gides
Seals
Glow plugs & harnesses
Resurface the heads .010 cut
All new gaskets & seals
I didn't spare anything on this job.
At this point it looks like an oil cooler failure. I will replace it. If it still has the same problem...I will buy an engine for it. I can buy a reman for about 4500 if I need to
Matt THANKS!!
Water pump
Radiator
Fan clutch
Thermostat
Oil cooler
1 new injector
ARP studs
Valve gides
Seals
Matt THANKS!!
- Skype ID: yes
That has to be discouraging, I have read alot about people having problems with the Black Onyx and Victor Reinz head gaskets. I hope that's not the case with yours.
Randall
Randall
1970 (Boss 302)
1970 (Boss 302)
- Region Leader
Randall,
Where have you heard that? Its something I would like to check out
- Skype ID: yes
Most of the information that I gathered was from the Powerstroke forum, if you do a search on the forum for Black onxy head gaskets you will get plenty of information from people that have had some bad experiences. I hope it's not that and I wish you good luck in getting her back on the road.
RAndall
RAndall
1970 (Boss 302)
1970 (Boss 302)
Rich, I have also heard to stay away from the black onyx gaskets. Im sure you will find the problem and have her back on the road in no time. keep us posted! and let us know if ya need anything
- Skype ID: yes
Rich, have you had a chance to diagnose what caused the failure?
Randall
Randall
1970 (Boss 302)
1970 (Boss 302)
- Region Leader
Actually, I will have all the parts tomorrow. Hopefully I'll be able to take it apart this weekend. I assume the case split on a seam between the oil and coolant but, we'll find out.
goodluck buddy! keep us posted. Are you taking the cab off again?
- Region Leader
NO WAY!! just have to remove oil filter hoousing and intake. Oil cooler right there. Biggest PITA is cleaning everything, UGH!!!
That was a JOKE buddy, I knew you wouldnt remove the cab again just for that! WHat was your difference in oil to water temp? did you have cross contamination? What drives me nuts is when somebody takes a 200000 mile motor, does the egr cooler and not the oil cooler while in there or vise versa....basically when you are gona have to take everything apart to do it again anyway. I know thats not what you did, but it is what our latest truck had done to it, so now I get to re- remove all the parts that were just put back on 6 monts ago....
Thats a benefit of doing it urself Rich, you will know what you did and not skimp.
Have you considered using the bullit proof oil cooler conversion?
Keep us posted in what you find, im quite curious
- Region Leader
I'm doing the Ford cooler cause...They are paying! It did cross contaminate. Just one of thoses things I guess. I'll let you know how I make out
NICE!...supposidly the bullit proof cooler is remote....i just wanted some feedback from an actual user . I have only used FORD ones so far, everything can have manufacture problems, good luck with the new one
try and post a pic of the failure if you can
