2004 Excursion Diesel?
I have an 04 Excursion with the 6.0L and the 5psd auto trans. My wife and I are looking to purchase the 35TBH TT and Ford says I only have an 11,000lbs tow limit. I have talked with the Hope family and they have the same setup and say they have no problems.
All the dealers say I need this or that extra to hand the 10,000lbs Red Bird we want. Some say a weight distribution hitch, some say just air bags. Some say NO air bags at all are needed. I'm hoping that someone here has answers that's not looking for more $$.
Thomas
Thomas
Going by what I know as someone who started with a TT and what you stated in your post, defiantly get yourself a weight distribution hitch, it will give you a better ride and help your truck handle the hitch weight. Be sure to also check your receiver hitch to make sure it is the proper class. As far as air bags, wait to see if you need them but remember they will not increase your load carrying capacity.
Hitch receiver
The factory receiver from Ford has a sticker on it. It says that it is a Class 5 unit, with only a 500lbs tongue limit. My dad's 86' Mazda pickup has a bumper tougue limit of 500 lbs. I think Ford is underrating the reciever because it states that it has a 12,000lbs towing limit too and a 500lbs tongue . Or maybe I'm just reading it all wrong.
Thomas
Thomas
- Shields
- Cardinal Owners: 31 RK LE
The 500# most likely refers to the hitch tongue weight allowed. Class 5 is the higher rated hitch so should be ok. Just have to limit the vertical tongue weight below 500#. But you will need the weight distribution equipment which most likely will work with your hitch. It allows for better weight distribution on the tow vehicle.
Most class 5 hitches have 2 sets of weights stamped on them, 5000lbs with 500lb tongue is usually the hitch without weight distribution, the other set of numbers should say something like 12000lb with 1200lb tongue or 10000lb with 1000lb tongue and this will be with weight distributing hitch and bars. I truely believe you would want weight distributing parts and sway control for your intended size for both comfort and safety.
Re: 2004 Excursion Diesel?
If this is the dry weight of the trailer, looks like you need more truck. Look at the GVWR of the trailer and go from there. The truck may pull it but will it pull it safely? Overloading the truck will damage the transmission (first).tagilles wrote: All the dealers say I need this or that extra to hand the 10,000lbs Red Bird we want...
Thomas
