Tire, Bridgestone Duravis R250
- Jash
- Cardinal Owners: John and Regina
2008 30 RKLE
2008 Chev LT DRW Diesel
JohnDeere 4710
CanAm 650 Mine
Forman 400 Hers - Location: Pennsylvania Marshburg
Has anyone used the Bridgestone Duravis R250 on their trucks. They have the size that will fit my truck. I would rather have michlins but id have to go up a size.
John and Regina
Retired, USCG
2008 30RKLE
2008 Chev DRW
Nights camped in 2012 160
Nights camped in 2013 134
Nights camped in 2014 160
Nights camped in 2015 160
Nights camped in 2016 160
Retired, USCG
2008 30RKLE
2008 Chev DRW
Re: Tire, Bridgestone Duravis R250
John, do the Michelin tires match an optional tire size for your truck?
Chief409 wrote:John, do the Michelin tires match an optional tire size for your truck?
Jeff, not sure if there was an optional tire size offered for the 2011 / 3500. The Michelin brand and size were listed as standard equipment on the window sticker.
Maybe on the dually mine came with Goodyear Wranglers which I got rid of and put Michelins on last year.
If you are looking at steel ply carcass tires for your truck. The Bridgestone Duravis M895 All Season might me a better choice. Still a steel ply carcass, but a better tread pattern for a drive axle. The R250 is more of a Rib tread than the Michelin XPS RIB!!! TireJash wrote:Has anyone used the Bridgestone Duravis R250 on their trucks. They have the size that will fit my truck. I would rather have michlins but id have to go up a size.
- Jash
2008 30 RKLE
JohnDeere 4710
CanAm 650 Mine
GM does not show an optional tire for the truck, Michlin will only recomend the OEM size.
John and Regina
Retired, USCG
2008 30RKLE
2008 Chev DRW
Retired, USCG
2008 30RKLE
2008 Chev DRW
Our came with the Bridgestone Duravis, I replaced them with the same tire.
- Jash
2008 30 RKLE
JohnDeere 4710
CanAm 650 Mine
Traveler, how many miles did you get on the orginal Bridgestones. How was the noise from the tire.Traveler II wrote:Our came with the Bridgestone Duravis, I replaced them with the same tire.
John and Regina
Retired, USCG
2008 30RKLE
2008 Chev DRW
Retired, USCG
2008 30RKLE
2008 Chev DRW
I replaced them at about 45,000 miles, they still looked good but we were heading out on a cross-country trip and I wanted good tires. I have about 35,000 on the second set. Noise was not an issue. The only thing they do is when I turn hard on say my cement apron going into my garage they leave marks on the cement. When I need new tires I will use the same tire, I like them.
Traveler II wrote:I replaced them at about 45,000 miles, they still looked good but we were heading out on a cross-country trip and I wanted good tires. I have about 35,000 on the second set. Noise was not an issue. The only thing they do is when I turn hard on say my cement apron going into my garage they leave marks on the cement. When I need new tires I will use the same tire, I like them.
Thanks Jim Sounds like a good endorsement to me for the Duravis! That is one of the tires Snoking has recommended as well!
