19.5 Commercial Tires For A Pick Up
I’m looking at the advantages and disadvantages of using the 19.5 commercial tires on my single rear wheel truck. I understand the advantages of greater load capacity. My question is how bad does the ride suffers by going this route? My wife has some health issues that get compounded if she gets bounced around too much.
Re: 19.5 Commercial Tires For A Pick Up
Yes they will likely ride a bit rougher, but very dependent on air pressure. On the 22.5 inch tires there is a significant difference in ride quality between running 110 psi & 90 psi (sufficient for my loads but lowest allowed on them). You would need to look at a pressure table for the tires you are looking at, compare what pressure you would need vs what you currently use. Higher pressure will result in a somewhat harsher ride. I've not tried it on a pick-up this is just my experience with big truck tires, the softer pick-up suspension may make it not as noticeable.
Thanks Bruce
Jane and I got back home last week and we're looking at either getting a new truck or putting money into what we have. If we keep what we have and put some money into it in many respects it will be better for pulling a fiver than a new one.
I'm thinking of using Rancho adjustable air shocks and put on stiffer springs and a heavy-duty sway bar along with the new heavier tires and rims, probably a little overkill. Add a new Max brake controller along with a Banks system, but I do need to be sensitive to the ride.
On the other hand the truck we have has done great pulling we would just move up to a one-ton and there are some good rebates out there on the 2013.
Now this is guy shopping and more fun than going to the mall—boys and our toys.
You have 17" rims now? For ride quality you would be better off staying with the current rim diameter and profile, and just go to wide tires and rims. 19.5 are going to be brick truck tires. A sway bar is not that big of a deal with a 5th wheel, as the load is not carried high like a truck camper. I love my Rancho 9000's. Took a load of firewood up to the trailer this morning. Stopped in town and turned them up half way as it was feeling a little loose. Straighten it right up. I let my rears down to 44 pounds when not towing to improve ride. Tires are 265/75R16E on 8.25 factory rims. Tires are rated to 3415 each.
Saw it today! Was waiting at the car wash for an Urkel wash & wax. Saw a F-350 (with 19.5s) pulling into the Lowes next door and had been watching pick-ups come & go for 25 minutes.n That was the only truck I "heard" crossing the speed bump over there, speed was similar to several others but my guess is that it felt very rough in the truck!
