For Sale 16" 110 PSI Rated Factory Alum. Wheels
Posted: Wed Feb 08, 2012 8:35 pm
I have four very good condition factory Aluminum wheels for sale, these are the Heavy Duty wheels that are designed for tires requiring 110 PSI operating pressures.
If you every went to upgrade your tire capacity to use a G rated tire you must use the 110 PSI wheels.
These are 16" wheels with a bolt pattern of 8 on 6.5" bolt circle, selling price for all four wheels, high pressure valve stems and center caps $250.00.
I upgraded from G rated tires to 17.5" wheels and J tires to reduce tire load and improve reliability, you can do the same by upgrading from E rated tires to G rated tires with these high pressure wheels.
360-414-7047
360-414-7047
