Winter Towing Question
Postby UT Cardinal » Thu Dec 07, 2017 7:29 am
I am going to be traveling from Utah to southern Texas after Christmas for a few weeks. I currently have the trailer winterized. I am wondering about the use of water while traveling to our destination, which may take 3 to 4 days? I suspect we will experience freezing temperatures for the first 2 to 3 days. The trailer is equipped with heated tanks and the underside is skinned with a sheet of plastic.
What do most of you folks do - travel dry until you are out of the freezing temps?
Can you travel with some water as long as the tank heaters are on? It seems to me like the wind while traveling would render the tank heater useless?
I hate to show my ignorance; however, there it is! First time traveling in the dead of winter.
2013 Cardinal 3030RS
2014 F-350 Lariat crew cab, short box
Husky 26K sliding hitch
Cummings Onan 5500 generator
Winegard SK 3005 satellite dish
2014 - 25 camping days
2013 - 10 camping days
2012 - 10 camping days
UT Cardinal
Re: Winter Towing Question
Postby rarebird » Thu Dec 07, 2017 2:43 pm
Hello UT Cardinal,
While I am no expert on the subject, having lived for a time in 4 degree weather, I found the "tank" heaters worked well while parked. I"m not so sure I would rely on them while travelling (due to current draw on the batteries). My opinion of "freezing temps while driving" should not be an issue as most if not all RV's are plumbed with PEX (plastic) lines which will expand somewhat in the short term. If you only travel 6-8 hours per day and turn on tank heaters at the end of the day, you should be fine. Problems might arise if the ambient temp is in the 0-20 degree range, but you are headed south, right ???
Running the refer and water heater on propane provides a further safeguard to the interior plumbing.
Hope this helps, I am sure you will get other opinions on the subject that we might both learn from.
Earl and Debbie Nattrass
Placerville "Old Hangtown", CA
2003 Platinum Cardinal 33TS
2002 Ford 7.3 Super Crew LB
rarebird
Postby UT Cardinal » Thu Dec 07, 2017 6:07 pm
Thx - I was thinking the tank heaters where to be used while being parked. I guess we will travel dry until we are out of the freezing temps.
UT Cardinal
Postby Don Wilson » Fri Dec 08, 2017 1:29 am
UT Cardinal
I will check with Triple J who travels from Minnesota in mid November to winter in Arizona and see what they do!
Don and Martha
2004 Cardinal 29WBLX
2006 Dodge 3500 2WD DRW Long Bed
2017 Nights Camped 59
2016 Nights Camped 96
2015 Nights Camped -129
Rallies Attended - 35
Frog - 4
Postby EAW » Fri Dec 08, 2017 5:09 am
I run dry until I get out of the freezing temps. If needed. I use RV antifreeze to flush the toilet by dumping it into the bowl while holding the foot valve open. Use baby wipes to clean hands. Refrigerator is on. Furnace is on and set to 55 degrees to keep things from freezing such as canned goods and other supplies that will freeze. These supplies are kept in totes setting on the floor and not inside of the cabinets along the outside walls. At the first campground out of freezing temps I put water in everything and set up for normal use. We usually only have to over-nite once in the freezing temps and its a little rugged but it works for us. An alternative would be to stay in a motel until you can use the camper. We reverse the process if needed when returning home.
Be very careful running the tank heaters without having enough water in the tanks so they don't overheat and possibly damage the tank.
Earnie, Penny, and Roxie
2007 Classic GMC Sierra K3500 SWR w/DuraMax, Allison
"Do not regret growing older. It is a privilege denied to many." unknown
EAW
Postby UT Cardinal » Fri Dec 08, 2017 2:42 pm
THX - EAW! That is very helpful info, I appreciate the feedback. We will travel dry until we are out of the freezing temps.
UT Cardinal
Postby Triple J » Fri Dec 08, 2017 4:54 pm
Earnie is right about traveling without water, we use a milk jug for the toilet. We stay in motel on the way Az
Jarnet and Jan Johansen
2015 Cardinal 3850 RL
2017 Chevy Duramax 3500 SRW
Frog Rallies 3
Rallies Attended-4
Nights camped in 2016-179
Triple J
Postby nra4life » Fri Dec 08, 2017 9:38 pm
If you are just concerned with the black tank, a big handful of rock salt will protect you from freezing down to near zero. That will allow you to use the toilet on the road. Roy & JoAnn
Roy & JoAnn Studer
2006 30TS Blue inside
2004.5 Dodge 2500 Quad Cab 4wd Diesel w/ Superglide, transfer flow 30 gal. tank/toolbox, Banks brake
nra4life
Postby UT Cardinal » Fri Dec 15, 2017 10:23 am
Thx for all of the good comments.
UT Cardinal
Return to Towing Discussions
Who is online
Users browsing this forum: No registered users and 1 guest
