Scary Contradiction!
- Cardinal Owners: Americana GS 38/39 RL3
Like many RV owners, I have a Tekonsha Prodigy P2 brake controller. I've used it for more than a year without trouble. It was chosen and installed for me by a reputable RV tech who does warranty work for FR. He also installed my brake system. I just found in the manual that this unit is NOT designed for use with electric-hydraulic brake systems. Tekonsha's website and other internet locations state clearly that the Prodigy P2 IS designed for use with electric over hydraulic disc brakes. Mine are made by Kodiak. I e-mailed them (Tekonsha) but no reply yet. Anyone happen to know what the -------- is going on!? I'm on the road crossing the continent again in a couple of weeks - just something else to worry about...
2009 Americana GS 38/39
08 Dodge 3500 Dually, Stick, K&N Intake, South Bend clutch kit, Cummins, Quad Cab, 4x4, 20K Star Performance Hitch
Re: Scary Contradiction!
I've used the Prodigy with Kodiac & Dexter Disks with more than 50K miles without issues. When Mor-Ryde put the Kodiacs on they even said the Prodigy is the best working controller for those brakes.
Well, I heard back from Tekonsha - Apparently, I have the original Prodigy brake controller - not the P2...The P2 was designed to work with all electric over hydraulic disc brakes and replaced the original in Jan. 2010. The original Prodigy (although it says in the manual that it won't work with EH brakes) does work with Kodiak and Dexter EH disc brakes because those manufacturers engineered them to work. So, anyone with a red LED display on the Prodigy has the original that will work with Kodiak brakes - the blue LED display is the Prodigy P2 - it'll work with any EH brake system...
Good info thank you.
- The-Bear
- Cardinal Owners: Americana GS31RL. a.k.a. Cardinal 29WB LX
I've got the original Prodigy and it works great with my electric over hydraulic disc brakes. I have the BrakeRite hydraulic system installed in my 2005 rig and it says the Prodigy is OK also.
Woody & Sandy
2005 Americana GS 31RL
a.k.a. Cardinal 29WBLX
I'm starting to wonder if there are any electric over hydraulic disc brake systems that don't work with the original Prodigy! Even though Tekonsha didn't design it to work it seems that the major brake manufacturers did engineer their products to be compatable. Either way, that info should be corrected in the manual that was supplied with the Prodigy...
For what it's worth, more and more manufacturers of many products ......are doing away with litturture , manuals in their product packaging, and going with "on-line" manuals, for that very reason, so they are up to date.
Call me old fashioned , but I still like a HARD COPY manual to look over, have ready . So, I do always look on line, because as you have learned, the latest info, will many times not jive , with the manual.
