Another vote for Prodigy , bur make sure the connector is clean . I had a bad ground this year . A little WD 40 cleaned this up
Wayne
Brake Controler
- Shields
- Cardinal Owners: 31 RK LE
I nowhave a prodigy P3. My Tekonsha Sentinel controller quit working coming over Wolf Creek Pass, 10000 feet high, and I had some smoking brakes by the time I got down. Would have been alright except I had a very slow car in front of me and the Pac Brake needed some help. But luckily no damage when they put it on the lift. So I picked up a new P3 controller. Easy to install, very easy to use, and now everything is in english and no codes to comprehend for troubleshooting. It worked very well going over some high passes today.
on it's way
Well with all you guys loveing your prodigy I just had to get one, It is on its way I will have it and install it before my next trip on the 12th, Thanks for your input guys.
Dave
Dave
