Hitch for 2010 Dodge 3500
tschmalz
Post by tschmalz »
A friend of mine just purchased a 2010 Dodge 3500, shortbed and is in the process of trying to find a 5th wheel hitch for it. He would prefer the "under the bed rails" set up but is being told they don't make that set up for the new vehicle. They are trying to sell him a set up that clamps to the frame. I have a 2005 Dodge and I know they specifically said you cannot clamp on to the frame. Does anyone have, or know of someone who has a 2010 Dodge and what type of hitch they installed.
Re: Hitch for 2010 Dodge 3500
You can clamp to the frame you cant drill the frame
Mike Clay wrote:You can clamp to the frame you cant drill the frame
Yeah, I thought it was no welding or drilling on the newer hardened frames. Clamping was what you are suppost to do!
rpfan
Region Leader
Post by rpfan »
Pull Rite makes a no drill application as long as you have the bolt on helper spring perches. They also now have an adapter kit to use Reese rails with their flush mount set up. It comes out to leave the floor flush when not in use
graham
Cardinal Owners: 2007 (cardinal) 31 RKLE tow vehicle 2006 dodge 3500 w/ ctd 6 speed manual W/ jake cool air box , no mufflr(sp?) onan 5500 gen set (lp) in 5er
Skype ID: ok to contact
Post by graham »
i have a valley slider on my 06 dodge short bed , its clamped on. it is my 2nd valley hitch, been very happy with it
Graham & Judy Winter 2007 Cardinal 31 RKLE 5500 onan lp gen set 06 Dodge Big Horn slt Cummins turbo 6speed man.trans w/ jake
dieselfreak21
Cardinal Owners: 2003 Cardinal 32 LX
Post by dieselfreak21 »
B&W has their turn over ball and then you add the companion. All under the bed. I like plus I can pull a goose neck if needed. It bolts up and is very solid. Not recommended to weld or drill on the new frames unless you know exactly what you are doing. There aren't many places that do including the dodge dealers.
Pooleparty
Cardinal Owners: Owners: 2006 30WBLE Trailaire suspension and king pin box
2010 Dodge 3500 diesel 4x4 SRW
HiJacker 16000lb. slider double pivot
Post by Pooleparty »
Just installed a 16000 lb. double pivot slider hitch made by HiJacker ( Victoria BC ) in my 2010 3500 4x4 short box Dodge. Bolted right in and fits well.
Kevin
