Drove a 2011 Silverado
Re: Drove a 2011 Silverado
This is out of their book: The electronic onboard warning system will provide a message alerting the drier when the DEF level is around 1,000 miles remaining range.
Additional messages that must be acknowledged alert the driver at the 300 mile, LOW and 0-mile fluid ranges as the DEF tank gradually empties. The fluid level in the DEF tank must be maintained for the vehicle to run correctly. If the DEF tank is allowed to run empty, the system will alert the driver. if fluid is not added at the net vehicle start, the vehicle speed will be limited to 55 mph and ultimately to 4 mph in accordance with federal requirements.
- rwlouks
- Cardinal Owners: 34 QRL (Taj Mah III)
Rob - you're correct, I miss read the manual. It gives a warning message at 800 miles at 300 miles and below it gives a message + chime. You can also do a system check and it will tell you if the DEF tank is less than 1/2 full. It is a 5 gal. tank.
Russ & Dawn
2008 34 QRL (Taj Mah III)
2011 Super Duty
2011 Super Duty
- rwlouks
Very similar language in the Ford manual. The speed limitations and other low DEF actions seem to be government mandated.Mike Clay wrote:This is out of their book: The electronic onboard warning system will provide a message alerting the drier when the DEF level is around 1,000 miles remaining range.
Russ & Dawn
2011 Super Duty
2011 Super Duty
- EAW
- Skype ID: eaward49
Question - does the DEF replace the DPF ?
No, but they have extended the miles traveled from around 300 miles now to around 700 miles before regen
HOLY COW, If I went to the dealer every 5000 miles, I would be there every other week!!!!!!!!!!!!!-------------OUCHRob & Cathy wrote:True, but I don't think there will be much to put up with. If it's brought in at least every 5000 miles for service the DEF will be refilled just like they refill the windshield washer fluid every time the truck is serviced.Mike Clay wrote: very nice truck just wish we did not have to put up with the def system but dont have a choice.
But the New Trucks sure are pretty................(I mean Tough looking)...... ) I saw a real Beauty of a 2011 F-450, or F-550 at the high end RV park , here in T.C. the other day.............White, with the grille/logo on the edge of the hood...............................................Course, the 5th wheel they had was no slouch either.
Whoa, you do put on a lot of miles.bfast54 wrote:HOLY COW, If I went to the dealer every 5000 miles, I would be there every other week!!!!!!!!!!!!!-------------OUCH
How often do you get your truck serviced?
Well It is all highway miles, I usually go, 10,15 thou. between oil changes, depends how it looks, and I get oil testing every so often. I know a lot of other people who run like I do, run synthetic........................ but I am kind of warry about switching.....................with the number of miles on old fashion oil. One of the drivers I know, runs 10 tho miles, changes filter, 10 tho ,more , filter, and at 30 thou full change.
My truck has had rotella since it was new (per original owner) ..and it is what I run also.
- rwlouks
Mike - I just noticed your signature line.... Did you do it????
Russ & Dawn
2011 Super Duty
2011 Super Duty
Well yes i did. Kind of got my self in a spot now but George will take care of that this weekend. You can not get a mounting kit for a hitch yet Reese has not even started making them and with Yellowstone getting real close need to get the hitch back on.
- rwlouks
Is is September already????? Did I miss August?????Mike Clay wrote:LOL save your money if I do it wont be until September. It was a crew cab long box, very nice truck just wish we did not have to put up with the def system but dont have a choice.
Russ & Dawn
2011 Super Duty
2011 Super Duty
OK, where's the pictures?
LOL well now you know why I have not posted that I bought one.
Well he did it and what a nice new ride it is, they keep increasing the weight limits and building these things stronger with larger frames,more power, larger disc brakes and the all new turbo brake.
Wow Mike is going to really leave me in the dust pulling now, does the Ford also come with the Turbo Brake that is what sold me on my GMC Topkick truck.
