I've been towing 5th wheels for 15 years
We have new {to us} Cardinal and Dodge P/U.
I found a #3300 Superglide w/rails&pins locally at a very good price. It is sitting in the bed of my tuck, too heavy for me to move it! I am not planning on installing the hitch until spring, could work on it this month but probably too cold. I would like to hang the hitch on the camper.
I've ordered the required brackets.
I ASSUMED that I could hitch to the Cardinal pin and use the Cardinal to lift it clear from the bed.
Wrong, the hitch will not close and latch.
Do I have to install a capture plate to close the hitch?
Suggestions?
SuperGlide Newby <<HELP>>
- Parno
- Cardinal Owners: 2005 Cardinal a 29WB, 5th Wheel. 3 weeks later a 2008 Dodge Quad Cab with Smoke Motor.
3000 Boliy Generator, 500 watts of solar
1000w Invertor, 2 Golfcart T-105 batteries, Bogart 2025 Charge indicator
Moryde ISR suspension (Best thing we;ve done!) - Location: Escapees Fulltimer
- Contact:
Peter & Anne-Marie Arnold
Member of Escapee's
National Camping Travelers, A Masonic Camping Group
2005 Cardinal
2008 Dodge RAM W/Smoke Motor
Somewhere, Texas
Member of Escapee's
2005 Cardinal
Somewhere, Texas
- jonandjolene
- Cardinal Owners: Blue Ridge 3125RT
Re: SuperGlide Newby <<HELP>>
I have a Super Glide slider hitch for my short bed Ford. There is a plate that needs to be welded to the trailer pin box for the hitch to work. Your dealer should be able to get one and install for you. I've heard that there is now one available that clamps on to allow for removal to pull the trailer with a conventional hitch that may also be an option for you.
Jon and Jolene
Both retired
2013 Blue Ridge 3125RT
Both retired
- Parno
- Contact:
I understand the the 'Capture Plate must be there to have the hitch lock up. Certainly not a plus feature. Next question, If you truck fails, can a conventional hitch hook-up with said plated welded on?
Member of Escapee's
2005 Cardinal
Somewhere, Texas
Member of Escapee's
2005 Cardinal
Somewhere, Texas
IMy BIL has the bolt-on plate for that reason. It allows you to take it off in the event that someone else needs to tow your trailer. You may want to contact Pull Rite and find out if they have it.
Our plate is bolted so it can be easily removed. The dealer ordered it when he ordered the hitch.
