Pull Rite CAptive Plate
Parno
Cardinal Owners: 2005 Cardinal a 29WB, 5th Wheel. 3 weeks later a 2008 Dodge Quad Cab with Smoke Motor.
3000 Boliy Generator, 500 watts of solar
1000w Invertor, 2 Golfcart T-105 batteries, Bogart 2025 Charge indicator
Moryde ISR suspension (Best thing we;ve done!)
Contact:
Post by Parno »
My Bird has a Fabrex Pin box. Not sure of the model number. The rig is about 200 miles away.
I've got the hitch, rails & custom brackets for my truck.
Now, I need captive plate.
Will the 'Universal', bolt-on captive plate work? Setting up to weld it will be a logistics nightmare.
Peter & Anne-Marie Arnold
Member of Escapee's
National Camping Travelers, A Masonic Camping Group
2005 Cardinal
2008 Dodge RAM W/Smoke Motor
Somewhere, Texas
jonandjolene
Cardinal Owners: Blue Ridge 3125RT
Re: Pull Rite CAptive Plate
Post by jonandjolene »
I don't know what the Universal one looks like. I have mine welded on but have heard the bolt on or clamp on styles will work. As long as it has the "V" to fit into the hitch to allow the hitch to turn and slide, it should work.
Jon and Jolene
Both retired
2013 Blue Ridge 3125RT
The side bolt on plates work the same as the ones that weld or screw from the bottom. You can even add angle to the weld on plate going up the side and make it a removable plate.
Parno
Contact:
Post by Parno »
Thanks for reply, I'm much more comfortable if it's removable in case of trouble on the road. Not too happy that I will not be able to go and rescue someone else's 5th if they are in grief.
Member of Escapee's
2005 Cardinal
Somewhere, Texas
rpfan
Region Leader
Post by rpfan »
Do yourself a favor and call Pull Rite. They will tell you which capture plate that you will need. Use one of the bolt ons. You will be much better off in the long run.
teallen
Cardinal Owners: 2012 3030
Skype ID: thomas.allen511
Post by teallen »
rpfan wrote:Do yourself a favor and call Pull Rite. They will tell you which capture plate that you will need. Use one of the bolt ons. You will be much better off in the long run.
I agree, I have a Pull Rite bolt on, only way to go.
Tom and Judy
2018 RAM 3500
9 grandkids (keeps us busy)
Rallys attended - 17
2019 Camping Days- 7
