Springtime and before driving checklists
On the way home this afternoon I saw a 5th wheel in the opposite lane with something strange on the roof. When it was close enough I saw that the driver had left the "batwing" antenna up, with the wings pointed fore and aft. The mast had folded over, the rear wing had bent, what I saw was the front wing sticking straight up. This makes around 5 RV's I've seen on the road in the last month or so with the "batwing" extended. It was just the first I'd seen with the mast folded over.
We're all pretty rusty after the winter layoff, so now is a good time to get the checklist out, and follow it. A goof might not be as simple as leaving the "batwing" up, something like not checking that the hitch IS locked, tire pressure, wheel lug nuts, the electrical cord properly locked into the plug is either Dangerous or will be expensive.
Have fun, and DRIVE SAFE
Re: Springtime and before driving checklists
Good idea Jeff.
I went and dug mine out. :thumbrt:
When I get hooked up the last thing I do is walk around the whole trailer to check lights, compartments are locked and shut, landing gear up, stabilizers up, fridge and hot water compartment locks, hooked up break away cable on, check tires for any bulges or low tires, then I walk away from the trailer and look at the roof to make sure antenna and vents are down. Taking a few minutes to do the walk around can save time and money down the road :thumbrt:
Yes even when we are using the trailer we need to check the checklist! On the tail end of the 5,600 mile trip last year on the way home from Mt Rushmore
L-) when leaving the campground in Albuquerque NM caught a small tree branch in the antenna because I didn't check the checklist .
No damage done but felt real :oops: :oops: !
Check the checklist!!!!!!!
RetiredFifthWheeler
Cardinal Owners: 3825FL Fifth-Wheel
Post by RetiredFifthWheeler »
Thanks for the reminder. We are headed out on Wednesday.
Wayne & Ruth Spong
2016 3825fl
2011 Dodge Ram 3500 / Cummins Turbo Diesel
Good Sam Life Members
Rallies attended - 3 (+ 4 FROG)
I always feel a little tentative when first heading out on a trip. One of the things I do in Arizona before heading home is Jack up each wheel, and wiggle and spin it. That way I tow not worrying about a bearing problem after driving to Arizona and then setting for 5 months. First day out I watch "things" like a hawk before settling in. Chris
One of the things I do after the wheels have been off is re-torque the lug nuts after I get the 'Bird home, a trip of 80 miles. Break each one loose, and torque it to the correct ft/lb using the "Star" pattern. Just putting the torque wrench on a lug nut, without breaking it loose first doesn't give you a good torque reading.
EAW
Skype ID: eaward49
Post by EAW »
Chief409 wrote:One of the things I do after the wheels have been off is re-torque the lug nuts after I get the 'Bird home, a trip of 80 miles. Break each one loose, and torque it to the correct ft/lb using the "Star" pattern. Just putting the torque wrench on a lug nut, without breaking it loose first doesn't give you a good torque reading.
I would think that would be like starting over and you would need to do it again every 100 miles. I know it takes a little extra to get the nut turning but I thought the idea was to tighten up any loose ones. If I reach my torque setting and the nut hasn't turned, I consider it tight enough and OK. What am I missing?
I do the same thing you do Earnie. When I checked mine before leaving on our trip I had one lug-nut that needed tightening.
EAW wrote: What am I missing?
Not a thing. Once you break the fastener loose, you will need to retorque after 50 or 100 miles.
bfast54
Post by bfast54 »
Correct...... Ernie, Rob, John.. :thumbrt: .......When Delivering trailers....I always stop at about 50 miles, torque, then at 100 miles, same thing, then 150 miles.... ;) .., then if I stop for fuel...I pull out the breaker bar, and just check. Had a couple of em loosen up over the years.
Course, Aluminum wheels more so than steel...steel ones tend to get to torque faster, and stay. Some pople look at you funny, but , they have no idea how to be safe...............
I am not going to chance a rig that Does NOT belong to me ..... :-o ...that gets expensive ... @-)
I did see a wheel going down the road by itslf one day..............it wasen't mine................. :YMPRAY: ..a guy pulling a flat bed lost one----- it was strange.....seeing it bounce down the road..... YMWHISTLE
BMullins46
Post by BMullins46 »
Hey! I had that happen on a pop-up back in '86, it's not a fun thing to have happen. I was just making my list of things to get done before we leave and check the lug nuts is on that list.
Checked mine when I brought the trailer home after having both rear tires off and had a couple that moved very little in just 32 miles. So yes you do need to check them.
