B&W Companion
- Cardinal Owners: Blue Ridge 3025RL
B&W Companion
Would like comments, both good and bad, from those using a B&W Companion, especially installation and removal issues.
Joel & Karen
2011 Blue Ridge 3025RL
2012 F350 Super Duty 6.7 4x4 CC King Ranch
- tc2kcard
- Cardinal Owners: 2000 Cardinal 35CKT
2008 Chevy CC, DW, D/A, B&W Companion - Location: Oklahoma Dewey
Re: B&W Companion
I have used the B&W Companion for 8 years with no problems. The unit breaks down into two pieces that are relatively easy to load/unload and assemble. Mine is a 15K. Also I like that when it is removed, the bed of my pickup is flat and with no obstructions.
Tom & Carol
Dewey, Ok.
2000 Cardinal 35CKT, 2 a/c, Qube Sat. Rec.
2008 Chevy 3500 DRW, CC, D/A, B&W Companion,Garmin GPS, 60 gal. aux.
Dewey, Ok.
Re: B&W Companion
I also like mine, it is a very tight unit with no movement, jaws always close around pin so it is always showing handle position to prevent slip out.
Re: B&W Companion
I have used mine since May 2007 and have been very happy with it. My pickup already had the B&W hitch I bought the Companion Hitch put it together and installed and remove it periodically when I need to haul something that I need the whole pickup bed for.
Re: B&W Companion
I did a lot of research before settling on the companion hitch and couldn't be happier with the purchase. Between it and our trail air pin box we've experienced a very smooth ride.
Re: B&W Companion
I just put a B&W turnover hitch,and companion in my New To Me truck........best move I ever made,smooth opperation,no noise,(like old reese), easy peezy hitch..........,release.....piece of cake.
Not cheap,but I feel.....money well spent.
Would do again in a heart beat.
- Secondhand Mike
- Cardinal Owners: 2004 Cardinal 29XL
Re: B&W Companion
When removing the hitch from the truck; after removing the top portion; do you just pull the handle under the fender and just lift the remaining part out. I watched a video on You Tube that was saying to loosen the u bolts. Is that actually true?
Mike and Cherryl Clem
2004 Cardinal 29WBLX
2008 Dodge Ram Quad Cab Long Bed 3500
6.7 Cummins Turbo 4x4 Dually
Rallies Attended - 4
FROG Rallies - 3
FROG Rallies - 3
Re: B&W Companion
You may be able to just pull the pin lever under the truck if the jam bolt on top of the square tube is not pulled real tight.
Because you suppose to tighten that jab bolt down to remove any looseness than tighten the U bolts .
This tightens the main hitch frame to the truck bed.
Re: B&W Companion
I have always pulled the handle under the fender and just lifted the hitch out. I have never loosened the u bolts. I do take a torque wrench and torque them every 6 months.
Re: B&W Companion
As a Safety measure............you are "Supposed" to put about 40lbs torque, on the bolt, on top of the Bar going into the Reciever................In Theory .......................some one could reach under, and PULL the Lever, and your ENTIRE hitch could come out.......................unlikely...........but, in a accident, when you would need it to be secure the most, that is when it could happen.
I recall, I believe it is 40 lbs torque.............................I do secure the lever, in place this way...............
