Trailer sway
- Cardinal Owners: 2019 3875 FBX/ 2019 Ford F-350 SRW King Ranch
Trailer sway
I am pulling a 2013 3450RL with a 2011 F-350 king ranch SRW and the trailer seems to sway quite a bit while going down the road @ 65-70 mph even with relatively low winds. My question is, is the trailer loaded incorrectly or is there other issues. I did upgrade tires and rims to Goodyear G114's for the heavier trailer and run them at about 115-118 psi. Any input would be appreciated. thanks
Kenny and Debbie Scholz
Kingsville TX
2019 Cardinal Luxury 3875 FBX
2019 F-350 SD, 6.7 king ranch srw
Kingsville TX
Re: Trailer sway
How level is the truck setting? Maybe you need air bags on the rear of the truck. How are the shocks on the trailer? Tires and inflation on the truck? Maybe you are ready for a duallie? Chris
Re: Trailer sway
The new trailers do not have shocks
Re: Trailer sway
They have not had shocks since early 2010 Like Chris said are you nose high or low?
Re: Trailer sway
I have air bags on the truck and it and the trailer ride pretty level. I run the factory Michelin 20" tires at 80 psi on the rear and about 75-78 on the front. And no it's not time for a dually, these things are to $$$$$$$ The truck only has 12,000 miles on it so the tires on both rigs are almost brand new.
Kingsville TX
Kingsville TX
Re: Trailer sway
Well if you are sitting level there really should not be any sway. Question is it sway or feel like its rolling. Does your pin box have an air bag? Do you run with any fresh water? Have you weighed the trailer to see what your pin weight is? Does the suspension on the trailer seem tight? I know lots of questions but trying to narrow it down for you. You would really have to load the front of the trailer to pack it wrong. There is not that much room for storage in the rear. I had 20's on my srw Chevy and until I bought this new trailer I did not have a problem. Only difference I ran 75 psi in the rear and 65 psi in the front tires. Depending on where your hitch sits over the rear axle you really do not transfer that much to the front so you are running the front tires pretty high
Your trailer empty probably weighed 13,200 lbs or so.(check the yellow sticker) Pin on that trailer empty is around 2,400 lbs. Go weigh it and see where you are now.
Re: Trailer sway
My pin box does not have an air bag on it, it is a trailair but no air bag. Also i do not carry fresh water on board. Maybe I should slow down a little bit to 60-65 mph. I sure don't want to drop another 65K on a dually.
Kingsville TX
Kingsville TX
Re: Trailer sway
Well if it was me this is what I would consider. Lower your front tire air pressure down to 65 or 70 psi. Put 1/3 tank of fresh water in to balance out the load some and slowing down is always a good thing. Give these things a try and see if you notice a difference.
- Cardinal Owners: 2008 30rk le
Re: Trailer sway
Is this a new hitch? If so it should be about 2" in front of the axel. Juse a thought....
Roger & Nancy
2008 30rkle
2008 Chevy 2500 Duramax
2008 30rkle
Re: Trailer sway
Thanks for all the good feedback guys, I will try these things out in August when I head to the Texas hill country. The hitch is new but the new Fords come with the bed pre rigged for the reese elite hitch. I just drop it in and lock it down.
Kingsville TX
Kingsville TX
Re: Trailer sway
All depends on the make of truck. Chevy is pretty much centered over the axle. Don't know about Ford and Dodge.ike wrote:Is this a new hitch? If so it should be about 2" in front of the axel. Juse a thought....
- Cardinal Owners: 2013 3450rl
Re: Trailer sway
Fords are also pretty much centered over the axle.
Kenny & Debbie
2013 3450RL, full body paint
2011 F-350 KR 6.7L long bed CC, SRW
Re: Trailer sway
I think that's where most get installed but I believe Ford recommends 1-2" in front of the axle.powerstroke1 wrote:Fords are also pretty much centered over the axle.
- emtdave
- Cardinal Owners: 2005 37RL
Re: Trailer sway
Puling a 2005 37 RL with a 2013 F350 PSD, crew cab SB, SRW. No sign of sway, even in cross wind. Trailair pin box, 20K Reese hitch, slider, 17/8" ahead of axle centerline, per Reese instructions. 20" Michelin 65 psi front, 80 psi rear per the truck sticker. Trailer tires are 14 ply, G rated running 110 psi. Towing attitude is just a hair nose high, truck is level. No water in the fresh water tank. I keep my road speed at 65-67 mph. Suggestion to add water may help balance issue, tire pressure and sidewall flex may have more of an impact, follow manufacturers recommendations when in doubt.
Have a good day, and good luck solving your issues. There is a wealth of information available within this group, these folks have helped me solve a number of problems.
Dave
Dave
Dave & Sue
Morgan (Golden Retriever) Pudd (the Fat Cat)
2005 Cardinal 37RL
2013 F350 6.7L Diesel, Lariat Trim, SB Crew Cab, SRW, 4x4
Reese Pro Series 20K Slider
2005 Cardinal 37RL
Re: Trailer sway
Maybe the issue is with the front tire pressure on the truck, I run them about 70 - 75 psi when towing the rv and 80 in the rear. I bought the Goodyear G114's @ truckandtrailertires.com and they recommended running them at 115-118 psi so I run them around 117 psi. Just noticed yesterday that both Michelins on the right side of the truck are missing big chunks of rubber from the same rib on the tires. So a trip to discount tire tomorrow to see what they will do about it, seeing that the truck only has 12,000 miles on it.$$$$$$$$
Kingsville TX
Kingsville TX
