I want to increase the distance between bed rails and overhang and the factory Ford hitch doesn't allow for adjustment. Here is my question, I currently have (5) bolts on each side of the pinbox that attaches it to the fifth wheel bracket, I would like to lower the pinbox (1) hole but, in doing so I will wind up with (4) bolts on each side, is 4 enough or should I not go this route.
Thanks,
Randall
Lowering Pinbox?
- Skype ID: yes
Lowering Pinbox?
2009 35sbq fifth wheel
1970 (Boss 302)
1970 (Boss 302)
Re: Lowering Pinbox?
Hi Randall, I've always had 4 bolts on each side of the pin box so it shouldn't be a problem.
- Skype ID: yes
Rob, thanks for the reply I appreciate your help. I believe that the 4 bolts should be fine, I am going to put B7 grade back in when I lower it, the originals are grade 5 bolts.
Randall
Randall
1970 (Boss 302)
1970 (Boss 302)
- Skype ID: yes
HOLD THE PHONE..........man do I feel stupid! I stated that the Ford factory hitch doesn't allow for any adjustment, boy was I wrong, I decided to look up under the king pin plate today and low and behold it can be adjusted. I was able to raise the hitch and inch and a quarter (problem solved).
1970 (Boss 302)
1970 (Boss 302)
Samsbird wrote:HOLD THE PHONE..........man do I feel stupid! I stated that the Ford factory hitch doesn't allow for any adjustment, boy was I wrong, I decided to look up under the king pin plate today and low and behold it can be adjusted. I was able to raise the hitch and inch and a quarter (problem solved).
