new rig and towing
Moderator: Don Wilson
kenny hodges
Cardinal Owners: 2003 31ts
Skype ID: no
new rig and towing
Post by kenny hodges »
just bought a 2003 cardinal 31 ts will be towing with a f250 super duty 4 door short bed diesel using a b w compain hitch what problems do i need to watch for ? this is all new have only had airstreams before thanks kenny
Re: new rig and towing
Kenny,
Congrat's on the new to you rig and WELCOME to CRVC. :thumbrt:
I pulled my 3150 with a F250 4x4 crewcab short box for a whole year. I just added air bags to the rear suspension.
bop11
Cardinal Owners: 2010 3150 RL
Skype ID: bill.bopra
Post by bop11 »
Welcome to the CRVC!! You've come to the right place.
Take a look at your tires and make sure they are in good shape and if they are Kenda, Carriers, or anything made in China make plans to get them changed ASAP.
kenny hodges
Skype ID: no
tires are on 7000 lb axles with goodyear 16 in tires worry about trailer hitting cab . have not towed going to pick up this week end in tenn. i live in va. thanks
I installed a Super Glide slider hitch. Hitting the rig was never an issue.
jonandjolene
Cardinal Owners: Blue Ridge 3125RT
Post by jonandjolene »
I, too, have a short bed Ford F250 and installed a Pull Rite Slider hitch and have had no problems at all. Also put air bags on the truck to level it out a little.
Jon and Jolene
Both retired
2013 Blue Ridge 3125RT
Leonard Kulaszewicz
K
Cardinal Owners: 2010 Cardinal 3625RT Fifth Wheel
2007 F350 6.0 diesel,short bed
Contact:
Post by Leonard Kulaszewicz »
I have a F350 with a PullRite slider hitch. I pull a Cardinal 3625 with it. My complaint is that backing up, I can only turn 45 degrees either right or left before my Trail-Aire pinbox hits the bedrails of the truck. My advice is, make sure you know how far you can turn before your pinbox hits the siderails of your truck when backing up.
Leonard and Barbara
2010 3625 RT
2007 Ford 350 Diesel 4x4 Short bed
watkinsk
Post by watkinsk »
For your F250, add a Pyro, Boost and Tranny gauge if you don't have them. Keep the tire pressure as listed on the trailer and on the truck. Finally, it sounds dumb but use a checklist when hooking up and unhooking. You would be amazed how many times the experienced tows get into a rush and create shortcuts that bite them in the rear.
This site has a ton of lessons learned from the school of hard knocks so enjoy them and LEARN!
Keith
R & D
Post by R & D »
Hi Kenny...welcome to the club! Enjoy your new bird!
