2006 F250 PSD
- mike & linda
- Cardinal Owners: 2013 3030RS
2006 F250 PSD
Can anyone tell me the best wired code reader for my truck? My check engine light stays on all the time. Ford always says it's the turbo sticking due to rust? because I don't drive it enough. $600 to clean. I'm a ford guy, but, beginning to think Dodge may have been a better choice for a diesel. I would like to purchase one that would tell me the problem not a code if possible. Also I would like to be able to monitor and to reset codes with it while driving. Thanks for any recommendations
2006 F250 PSD CC
2013 3030RS 5er (The Load & Go}
DW & #1 Son
DW & #1 Son
- trouble1263
- Cardinal Owners: Cardinal 29 TSLX Fifth Wheel
Re: 2006 F250 PSD
I can't give you the answer your looking for, but I can refer you to a great forum called Ford Truck Enthusiasts.
http://www.fordtrucks.com
There is a 6.0 forum that will have your answers..This has been a great resource for me with diagnostic and repair to my 7.3l
Duane & Wendy
2005 Cardinal 29 TSLX
2014 Ram 3500 Crew Cab Long Bed/ 4x4 / 6.7 L Cummins/Aisin 6 Speed Auto/Factory 20 In Wheels
Re: 2006 F250 PSD
I use an Edge Insight to monitor my engine, transmission and cooling temps in addition to turbo boost and EGT temp. It also reads and clears codes but it doesn't tell you what they are. The one I got is http://www.edgeproducts.com/product.php?pk=145&pvk=405
Re: 2006 F250 PSD
Mike,
I think you looking for a lot out the code reader devise, even resetting the active code will not keep it off if the fault remains active.
I am not sure but I think have not seen the over the counter units display the problem code in words of the problem like the dealer units.
Re: 2006 F250 PSD
This is what I have Mike:
https://play.google.com/store/apps/deta ... owl.torque
Along with this:
http://www.amazon.com/BAFX-Products-Blu ... B005NLQAHS
Along with the error code if you have Inet access it will give more detailed information on the code.
Along with this:
- mike & linda
Re: 2006 F250 PSD
Thanks guys. I could not find one that would tell me the actual problem either. I will probably go with the wifi model on amazon with the android app. I think my truck has some inherent problems that will need to be addressed. The turbo sticking is due the fact that I only use it to pull the 5th wheel. 06 with 50k miles, guess I need to drive it more. Thanks for the help
2006 F250 PSD CC
DW & #1 Son
DW & #1 Son
- Skype ID: yes
Re: 2006 F250 PSD
Mike, I would go with the Edge Insight. I bought one for my 2006 and still use it for my 2012. They are a great tool and will allow you to diagnose problems.
2009 35sbq fifth wheel
1970 (Boss 302)
1970 (Boss 302)
